| auto hub clicking and not engaging swb j20 5 speed http://auszookers.com/forum/viewtopic.php?f=5&t=23209 |
| Author: | dungbeetle [ Fri Jun 24, 2011 6:01 am ] |
| Post subject: | auto hub clicking and not engaging swb j20 5 speed |
if anyone had a look at my other thread, well they will know im an idiot!! turns out the free wheeling hub is having a problem. i pulled it apart and all looks good inside but im not really sure what it should look like. what generally stops working on these hubs? the passenger side one seems to be working, well its not clicking anyway!! |
| Author: | Fatzook [ Fri Jun 24, 2011 6:02 am ] |
| Post subject: | Re: auto hub clicking and not engaging swb j20 5 speed |
Why start another thread? |
| Author: | dungbeetle [ Fri Jun 24, 2011 6:08 am ] |
cause its a different problem, and when someone searches for auto hubs, they probably wont look at a topic that says blown up diff. well i wouldnt look at it anyway. mods can delete this one if they want.... |
| Author: | Fatzook [ Fri Jun 24, 2011 6:12 am ] |
Dozens of threads on auto hubs. Not sure that your problem is unique. http://auszookers.com/index.php?name=Forums&file=viewtopic&t=20546&highlight=auto+hub http://auszookers.com/index.php?name=Forums&file=viewtopic&t=19943&highlight=auto+hub http://auszookers.com/index.php?name=Forums&file=viewtopic&t=19579&highlight=auto+hub http://auszookers.com/index.php?name=Forums&file=viewtopic&t=11771&highlight=auto+hub http://auszookers.com/index.php?name=Forums&file=viewtopic&t=8859&highlight=auto+hub |
| Author: | dungbeetle [ Fri Jun 24, 2011 6:27 am ] |
first 2 threads are on jimny hubs, not sure if they are the same as vitara. the third one is a question whether ya can have auto hubs with an auto locker. the 4th one is whether to have auto or manual hubs and the 5th one is about the v6 model which from reading the thread seems it doesnt have auto hubs but a drive plate or something. i admit i dont know anything about how these dam vitaras work, but i am trying to work it out. if nothing ever goes wrong with these hubs then perhaps it is the cv clicking, but i stood next to the wheel and it sounded liek it was coming from the hub. |
| Author: | atari4x4 [ Fri Jun 24, 2011 6:33 am ] |
check you CV joint to see if it's damaged, could be a simple fix of remove & replace. |
| Author: | Westie [ Fri Jun 24, 2011 7:09 am ] |
Normal problem is thick grease like tar and or the grease is brown from water / rust just get a set of Free wheeling hubs and put them on. |
| Author: | dungbeetle [ Fri Jun 24, 2011 8:53 am ] |
will check the cv tomorrow, and take apart the hub again and give it a clean up. or just forget about it and avoid going in the mud!! |
| Author: | atari4x4 [ Fri Jun 24, 2011 9:00 am ] |
if the CV is properly dead, you should be able to grab the 1/2 shaft & "stir the pudding" inside the CV cup. |
