It is currently Fri Oct 16, 2026 1:45 pm
Post Posted: Fri Jun 24, 2011 7:20 am
Hi.
Is it easy enough to replace the oil sump on a 92 vitara G16B while the engine is still in?
It looks like there ain't much room between tranny cross member etc.
Is it possible to replace or do you have to pull motor or maybe just undo engine mounts and lift it up enough with an engine crane?
Any hints appreciated.
Post Posted: Fri Jun 24, 2011 7:30 am
yep you can do it, ive done it on mine which is an B block and A sump but id gather the sumps are about the same, remove front diff which is pretty easy, turn the wheel to full lock and there will be just enough room to do it.
though i did it on a hoist which is easier to reach stuff, i did it cos i wasnt gonna take motor back out for that oil leak
Post Posted: Fri Jun 24, 2011 7:36 am
Yeah. The annoying thing for me is that I had my engine out last weekend for a swap and didn't notice that the new import engine had a ding in the sump till after it was in. The lowest point of the sump (where the plug is obviously) has been bashed up which means that there will always be a certain amount of dirty oil that won't drain out.
Got do do an engine mount this weekend anyway so guess I'll do the sump too.
Post Posted: Fri Jun 24, 2011 7:37 am
Is it hard to pull the front diff out?
Vehicle: Daisy
Post Posted: Fri Jun 24, 2011 7:40 am
What about jacking the chassis up and putting it on stands so the diff hangs down at full extension? Would that give you enough room?
Post Posted: Fri Jun 24, 2011 7:46 am
not hard at all, but teracis's idea wont work cos its IFS on a vit.
just undo the axel off the side of the diff, undo the drive shaft and the mounts on the front diff and you can slip the other axel out, all without taking wheels or hubs off just feeling my way through without having done it before took 20min but once again ill point out i was using a hoist so its really easy when you can stand underneath,
yeah i share your annoyance i was in a similar boat id just rebuilt the motor, and was leaking in one spot, and really didnt want to take motor back out also
That could work.
Guess there's only one way to find out!
Post Posted: Fri Jun 24, 2011 7:54 am
fluffoffal wrote:
That could work.
with IFS you don't really get much movement at the diff. :wink:
Vehicle: Daisy
Post Posted: Fri Jun 24, 2011 8:19 am
My bad, I keep forgetting they are IFS front, all I've got to go off is my sierra :p
Also, at the risk of wrecking the sump, since you say the bolt is knocked in anyway, could you put an eye bolt in the sump plug hole and pull the ding back out?
Just an idea, as I said, might ruin the sump...
EDIT: Actually that's just being really lazy, just take the sump off and fix it while it's out :p
Users browsing this forum: No registered users and 208 guests
