It is currently Tue Oct 27, 2026 9:53 am
Post Posted: Thu Aug 11, 2011 12:43 am
tools needed.
2x 14mm spanners
1x big fuck off hammer
a couple of sockets to use as a drift. borrowed sockets are best. :wink:
a longish drift. 3/8 socket extension will do.
internal c-clip pliers.
small length of pipe with a ID larger then the uni caps
large vise.
pull the tail shaft out of car and stick it in a vise like this. remove c-clips, stick the
pipe over the uni cap and flog the piss out of it
when the cap sticks up a bit flip it over and flog the opposite cap.
keep flogging opposite caps until one pops off.
then put the pins in the vise and with out hitting the caps bash the yoke
down until the uni falls out.
ready for reassembly
will finish after smoko.
Post Posted: Thu Aug 11, 2011 12:55 am
note to self: :helloo:
never loan tools to Shep :roll:
Actually- thinking about it- my sockets/ extensions etc would probably last longer if left to Sheps tender mercies :oops:
Post Posted: Thu Aug 11, 2011 1:08 am
Surprised you even used a hammer. Thought you would have a prime bashing rock instead :lol:
I also like to mark my yokes so the go back in the exact same position
Lil Foot!
Post Posted: Thu Aug 11, 2011 1:51 am
Keep going Shep - I reckon only 1 in 25 members here know how to do it
Post Posted: Thu Aug 11, 2011 2:11 am
i replaced 6 unis on my zook. what a pain in the arse
Post Posted: Thu Aug 11, 2011 3:09 am
where was the 6th one lol
good goin shep,unis suck
Post Posted: Thu Aug 11, 2011 3:11 am
2 in each shaft!
3 shafts = 6 :)
Post Posted: Thu Aug 11, 2011 3:20 am
2 in each shaft!
3 shafts = 6 :)
:lol:
Lil Foot!
Post Posted: Thu Aug 11, 2011 3:22 am
That's why the softcock gives them to me to put back in :x
Post Posted: Thu Aug 11, 2011 3:25 am
remove 2 caps from new uni and insert into yoke
stick uni into cap and then tap the yoke onto the cap. stop often and make sure that
none of the rollers have dropped out
tap the second cap into the yoke making sure it still moves smoothly.
tap the caps in past the c-clip groove with a socket on the bottom.
remove the last two caps and stick one in the other yoke and gently tap it home
remembering to check that the uni moves smoothly and isn't binding.
tap the second cap on.
stick the socket under the cap and tap it past the c-clip groove.
camera died so no more photos
stick the c-clips in there home and tap the caps into the right position
when the uni is assembled ensure that it moves smoothly and freely, if not then
rest the yoke on a vice and tap with a hammer.
refit tailshaft and do burnouts. :wink:
Post Posted: Thu Aug 11, 2011 3:26 am
yep. use balls tools and get him to do the shit bits
Post Posted: Thu Aug 11, 2011 3:42 am
You forgot to add your last step,
leave all your mess and shit laying around for me to pick up :?
Post Posted: Thu Aug 11, 2011 3:49 am
nope i just cleaned up the mess. well i kicked all the shit under the work bench.
Vehicle: 4wd
Post Posted: Thu Aug 11, 2011 3:53 am
Pics of burnouts.
Watch out or you'll get sued.
Post Posted: Thu Aug 11, 2011 4:02 am
stockman wrote:
Pics of burnouts.
Post Posted: Thu Aug 11, 2011 4:21 am
There is an even easyer way than using a drift to belt the caps out. I will post later on tonight.
helloo
Post Posted: Thu Aug 11, 2011 10:23 am
Yep, cut a 25mm long length of the large pipe. Place yoke in vice with large ID pipe on one side and socket (smaller the 24mm OD) pressing up against Uni on opposite side. Slowly tighten vice and Uni Cap will be pressed out. Undo vice and flip yoke over to do other cap, but make sure that socket used this time is smaller than bearing surface of uni, or else you will press socket permanently onto Uni.
Post Posted: Thu Aug 11, 2011 10:52 am
Or use a big fuck off copper hammer and belt it a few times and it's out. :wink:
I can do a uni twice as fast with the hammer as can be done with a vise or press
Post Posted: Thu Aug 11, 2011 12:01 pm
I thought Shep was the rough bastard?
Post Posted: Thu Aug 11, 2011 12:03 pm
He is,
How is using a copper hammer rough?
Works fine if you know what you are doing.
You have more chance of doing damage with a press or a vise.
Post Posted: Fri Aug 12, 2011 3:07 am
so where was the 2nd uni on the other end of the jackshaft???thats why i asked :lol:
i was assuming sierra going by the display pic.
Burnout looks good :D
Post Posted: Fri Aug 12, 2011 3:14 am
the jack shaft has 2
front tail shaft has 2
rear tail shaft has 2
Post Posted: Fri Aug 12, 2011 3:20 am
X2 or X6 in that case :wink:
Lil Foot!
Users browsing this forum: winchzook and 188 guests
