It is currently Tue Oct 13, 2026 8:13 pm
Post Posted: Fri Jun 24, 2011 11:26 pm
Hi all...
I'm mounting a power steering cooler today and looking at where to run the tubing etc.
My question is this, does it matter if the cooler or hoses are higher than the reservoir?
I'm wondering if it a potential air trip that I should avoid but the instillation will be heaps easier if the hoses run higher.
Ta
Post Posted: Fri Jun 24, 2011 11:36 pm
you shouldnt because once you turn it off the fluid will drain back down causing the resivour to over flow so try and keep it under the level of the resivour
Vehicle: 4wd
Post Posted: Fri Jun 24, 2011 11:37 pm
You may also find it difficult to bleed the system.
Watch out or you'll get sued.
Post Posted: Fri Jun 24, 2011 11:43 pm
DSzuke wrote:
Hi all...
Ta
My guess is the same as yours, that you're going to get air pockets in there.
I mounted my res up high, off the radiator support bracket
and the cooler down low behind the grille
Is there any reason in particular you want to have the cooler up high? If you really need to mount it up high you coul put in a bleed valve to bleed out the air. You could make up a little bleeder in line with hose tails on each side and a normal ole brake bleed nipple. That would allow you to put a hose on it and bleed it without getting fluid everywhere.
Of course the easiest way would be to mount the cooler down lower.
Post Posted: Fri Jun 24, 2011 11:53 pm
thanks for all the quick replies :D
Yep I was suspecting having it up too high might be a problem.
I think I'll ponder some more :lol:
Post Posted: Fri Jun 24, 2011 11:55 pm
I hate it when I make typo's :x
Users browsing this forum: Google [Bot] and 250 guests
