http://auszookers.com/forum/
Fitting wt flanges to a 1 liter transfer case
http://auszookers.com/forum/viewtopic.php?f=5&t=23240
Author:  screwloose [ Sat Jun 25, 2011 10:11 am ]
Post subject:  Fitting wt flanges to a 1 liter transfer case
Hi there just wondering if you can fit WT flanges to a 1litre transfer case?
I have pulled off the NT flanges and they are smaller than my WT flanges.
Is there WT flanges that fit?
Author:  89_tintop [ Sat Jun 25, 2011 10:13 am ]
Post subject:  Re: Fitting wt flanges to a 1 liter transfer case
Is it a 1litre tcase with a switch?
Author:  foolsp33d [ Sat Jun 25, 2011 10:16 am ]
combo 1.0-->WT unis... mix n match till it works
Author:  screwloose [ Sat Jun 25, 2011 10:43 am ]
Yep it's a switch transfer case
Author:  SierraDan [ Sat Jun 25, 2011 10:55 am ]
the WT flanges will go straight on then.
Author:  screwloose [ Sat Jun 25, 2011 11:12 am ]
No they are to big and go straight over the splines and spin.
Author:  Bruce [ Sat Jun 25, 2011 11:18 am ]
Well it's not a 1lt case with a 4x4 light switch then. You must have a early 1lt case.
Author:  Fatzook [ Sat Jun 25, 2011 11:18 am ]
Then you have an early model case and you're shit outta luck. :lol:
Author:  Bruce [ Sat Jun 25, 2011 11:19 am ]
Beat ya by less than 1 min Peter. :-)
Author:  screwloose [ Sat Jun 25, 2011 11:23 am ]
It's a switched 1 litre, got the plug hanging off it. Are diff flanges bigger in the spline size.
Author:  Fatzook [ Sat Jun 25, 2011 11:24 am ]
Better keep me away from your missus then, seing as I take longer and all :wink:
Author:  Bruce [ Sat Jun 25, 2011 11:26 am ]
bwhhahahahahah 8)
Author:  screwloose [ Sat Jun 25, 2011 10:42 pm ]
Are diff and transfer case flange internal spline sizes different?
Author:  89_tintop [ Sat Jun 25, 2011 10:45 pm ]
Dont quote me on this .. But I am pretty sure they are..
It sounds like you have a early 1 litre case.. I have done what you are doing and had no dramas fittung WT flanges.
Author:  zooky08 [ Sat Jun 25, 2011 10:57 pm ]
So your saying that it has a switch with wires coming out of it down near your shifter
If this is correct then wt flanges will fit
Are all you spline still there, not warn out. etc.
Author:  2stroker [ Sun Jun 26, 2011 1:21 am ]
If it has this then a WT flange should fit.
Author:  SierraDan [ Sun Jun 26, 2011 1:22 am ]
milkcrate :D
Author:  SierraDan [ Sun Jun 26, 2011 2:26 am ]
26 spline flanges should go on. check your flanges.
Author:  royce [ Sun Jun 26, 2011 2:39 am ]
I wonder if somebody has stuck a later front housing onto an early transfer
Author:  Fatzook [ Sun Jun 26, 2011 4:13 am ]
Thats what I was thinking. Its common for people to not remove the circlip from that front housing section before trying to press out the bearing, causing the housing to break. I'd say that its got a later model housing on the early case.
Can we have some pics of the mounts?
Author:  303zuke [ Sun Jun 26, 2011 9:30 am ]
The "Early" (w/o switch) and "Late" (w/ switch) cases are completely different and none of the case castings will mix.
However, early Type 2 Sierras (1982) came out with a switch on the front case before the introduction of the later style of case we all now know as the 1.0lt with switch. They were pretty rare, I only ever recall seeing one and I think they were a stopgap measure until production of the later case caught up with production of the Type 2.
These rare cases will have the same case casting as the normal "without switch" case (Type 1), but with a switch:
Author:  screwloose [ Mon Jun 27, 2011 7:19 am ]
My case has the switch on the front and wires coming out to the plug.
Still no good the WT flanges are to big in the spline bore size.
Any more suggestions?
Author:  SierraDan [ Mon Jun 27, 2011 7:40 am ]
do your shafts have 26 splines?
Author:  Fatzook [ Mon Jun 27, 2011 7:47 am ]
It doesn't matter. He obviously has the older case. There are only one size of WT flanges and since they don't fit, it is irrelevant.
OP if you MUST run the case you will have to make hybrid driveshafts with 1L yokes so they can bolt to the transfer flanges.
Author:  SierraDan [ Mon Jun 27, 2011 7:53 am ]
Thats what i was trying to get out of him..
