http://auszookers.com/forum/
power steering problems
http://auszookers.com/forum/viewtopic.php?f=5&t=23377
Author:  slowsierra [ Tue Jun 28, 2011 7:33 pm ]
Post subject:  power steering problems
hi guys,
i am having a problem with my power steering on my sierra. here are a few details on the setup. i have a '91'sierra with a baleno engine and vitara power steering mounted via a BenT adpt kit. so the problem is it seems to build up resistance as i turn the the wheel to steer then it goes easy then builds again etc this happens a couple of times as go around a corner/turn the steering wheel. i am stumped on the problem. i am thinking of getting new hoses installed just to narrow down the list. i have bleed the system (jacked the front up and turned the wheels from lock to lock a few time). any help will be greatly apprecated.
thanks greg
Author:  rick1970 [ Tue Jun 28, 2011 8:00 pm ]
Post subject:  Re: power steering problems
Kingpin bearings?
Author:  94BAZOOKA [ Tue Jun 28, 2011 8:06 pm ]
Are the lines the right way ?
Author:  hutch [ Tue Jun 28, 2011 8:26 pm ]
what did you do with the steering shaft from the wheel to the PS box? Did you replace it with the coily one? What is the condition of the rag joint?
Author:  steve [ Tue Jun 28, 2011 8:37 pm ]
Here's a thread with my power steering issue...
http://auszookers.com/index.php?name=Forums&file=viewtopic&t=21474&highlight=power+steering
i got a new V6 pump and it worked.
I have a spare 1.6 pump if you wanted to try it. (it's not the old one that didn't work)
Author:  want33s [ Tue Jun 28, 2011 8:42 pm ]
Shagged uni's in the steer shaft?
Author:  31zook [ Tue Jun 28, 2011 10:51 pm ]
the steering slop adjuster is too tight? Is it when your steering wheel get to one point only or is it all different places on the steering wheel?
Author:  Hybrid [ Tue Jun 28, 2011 11:01 pm ]
x 2 to rubber rag joint or binding uni's. I've had both after doing my PS.
Author:  oozuk [ Tue Jun 28, 2011 11:06 pm ]
Did you bleed he power steering system when you installed it? Could have air still in the system. Does the pump groan when you loose power steering ?
Author:  Jasen [ Wed Jun 29, 2011 7:45 am ]
He said he has bled it, but I was thinking the same as u oozuk. When you installed the ps lines - you don't have any lines that go above the reservoir or have high spots where air could still be trapped?
Author:  slowsierra [ Sun Jul 03, 2011 8:17 pm ]
you picked it like a dirty nose Want33's. i had a spare steering shaft/uni so it was an easy fix.
thank you all for your input i checked everything else while i was there. and re bleed the system. tested it out at ripleys was going great til my mate blew his CV. when will people learn not every car can follow a sierra :lol: :twisted:
