It is currently Sat Aug 01, 2026 10:17 am
Post Posted: Wed Jun 29, 2011 8:31 am
G'day guys looking at buying my first sierra but first I have a few questions and hoping you could help me out.
Do I need a body lift to run 30" - 31" tyres or is just a suspension lift okay?
How much/ hard is it to replace swivel hub seals (91 sj70)
Is a 91 SJ70 a WT model?
How many km's are too many km's?
What is the chance that a soft top leaks?
sorry for all the questions but I'd rather be safe then sorry
Adam
Post Posted: Wed Jun 29, 2011 8:42 am
Either Either. You'll need bumpstop extentions with a spring lift. Are you going to run reduction gears? cos it will drive like an expensive piece of dogshit otherwise.
Not that hard in my opinion, depends on your skills.
Is a 91 SJ70 a WT model? Yes
Over 200k is accepted as "getting on". But it depends on how its been treated.
What is the chance that a soft top leaks? Depends on the condition. Mine is perfect.
Adam
Post Posted: Wed Jun 29, 2011 8:45 am
Thanks for that dan , I'm a 2nd year apprentice mechanic so I should be okay with the hubs , but I've been told they can be a 5 hour job?
Post Posted: Wed Jun 29, 2011 8:46 am
No BL required....but you will have to do a guard chop. Cheaper and easier to do BL.
Hub seals are easy if you are mechanically minded
Yes WT
How long is a piece of string?? Depends, it could have had a rebuild etc
Not all softop's leak, you might be lucky. I don't think I have ever seen one that is completely waterproof, you will most likely get some leaking albeit a tiny leak
Could be. I take my time to get it right and proper the first time. But somtimes things can be a royal bitch.
Just like some people take days to try and undo transfer flanges. Took me about 2.653 seconds.
Post Posted: Wed Jun 29, 2011 8:47 am
Stupid iPhone typing :roll: ^^what he said :lol:
Post Posted: Wed Jun 29, 2011 8:54 am
http://www.auszookers.com/index.php?nam ... ic&t=23397
Do I need a body lift to run 30" - 31" tyres or is just a suspension lift okay? 31's i'd say yes unless your happy with chopping the guards a bit (AKA virtual lift). You can get away with 235's & 30's with just "persuading" the seams with a hammer. You may need to trim the front outriggers depending on rim offset.
How much/ hard is it to replace swivel hub seals (91 sj70) Just the wiper seals behind the knuckle? Cheap/easy as. However I'd be more inclined to do wheel/king pin bearings/seals at the same time if the swivel hub seals are on their way out.
Is a 91 SJ70 a WT model? Yes.
How many km's are too many km's? Any gettin close to the 200k mark are probably gettin a bit tired.
What is the chance that a soft top leaks? Moderate to high unless it's pretty new.
Adam
Post Posted: Wed Jun 29, 2011 9:02 am
thanks guys , also which is the better option softie or hard top ?
I like the soft tops but It will live on the street and I'm concerned about security
Post Posted: Wed Jun 29, 2011 9:11 am
I have a softtop and worry about security. But at the same time i dont leave things in the car and make it pretty damn difficult to steal. But i like my soft top for 4wding, you can have the top off and a soft top hoop is easier to replace than a hard top roof when you lay it over :D
Post Posted: Wed Jun 29, 2011 9:20 am
wow i type slow lol... there were no replies when i started my post lol.
I've owned 2 soft tops and have been lucky regarding break ins (although my cattle dog did eat a hole in the driver side rear of it chasing trucks all the way from Cairns to Brisbane). Just don't leave tools or any items you'd be screwed without in the zook.
Vehicle: SJ80, SE416
Post Posted: Thu Jun 30, 2011 6:37 am
Tyres will preobably scrub on the guards without one.
Nope - get used to doing some maintenance.
Yep.
How long is a piece of string. My pretty much 100% reliable daily drive has nearly 320,000km and my POS play thing was already stuffed at 165,000km - all depends on maintenance.
Pretty good chance - the Sierras are hardly designed to be weatherproof.
Post Posted: Thu Jun 30, 2011 6:41 am
Don't leave valuables in it and don't install an expensive stereo and you'll be fine.
Post Posted: Sun Jul 03, 2011 5:17 am
my zook has done 330000 and still going strong. as far as i am aware there a prety easy engine to rebuild (ive been told) anyway.
THINKING BEFORE POSTING!!!
Users browsing this forum: Google [Bot] and 318 guests
