It is currently Fri Jul 31, 2026 9:05 pm
Post Posted: Thu Jun 30, 2011 8:58 am
Hi All,
Searched but nothing really found. My temperature gauge moves under acceleration....yes that is not a typo. Sits under half when stationary then drops to under C when accelerating.
Also, my 4wd light in the dash comes on and off, under acceleration also.
Possible earth fault??? Where do I find the culprit if it might be the case??
Help 8O
Rusho
Vehicle: Daisy
Post Posted: Thu Jun 30, 2011 9:12 am
Can you see any loose wires hanging in there?
Sounds like something is crossed up!
Maybe a hole has rubbed in the insulation on a pair and is crossing them over?
Can you park on a hill (to simulate acceleration) and unplug both of the wires causing issues (temp sender and 4wd light) and then test them?
EDIT: Apparently it's most likely to be an earth fault as below (for anyone who's searched and found this).
Post Posted: Thu Jun 30, 2011 9:13 am
Check you earth wire from the body to the battery, could be only getting an earth through the acc cable by the sounds of it.
Vehicle: '95 lwb vitara
Post Posted: Thu Jun 30, 2011 9:25 am
I had the same problem with my Vit mate, add a heavy gauge Earth wire from your body to your battery and should be sorted.
Post Posted: Thu Jun 30, 2011 9:37 am
mine was doing the temp thing the other week, 2800rpm it went nuts
I just crimped the terminal up and pushed it back on :)
unplug the transfer switch, see if that fixes the light
Post Posted: Thu Jun 30, 2011 9:44 am
i had the same problem with my vit temp used to move with revs found that sender unit had a bad connection and the backflow from the fan was causing the temp to move. squeezed the lug and slip it back on and the guage hasn't moved since.
Post Posted: Thu Jun 30, 2011 9:45 am
Burn it..... :helloo:
Post Posted: Thu Jun 30, 2011 9:49 am
:finger: :finger: :finger:
Post Posted: Thu Jun 30, 2011 9:56 am
That conveniently happened to a caryard car that was going to cost them an arm to repair. (not anyone that I work or have worked for) was left out side one day.. And come in the next day and it was burnt out
Post Posted: Thu Jun 30, 2011 10:31 am
What, all (ok most) of your problem's would be fixed in one smoky swoop.. :helloo:
Post Posted: Thu Jun 30, 2011 11:17 am
and there are two bonuses.
1 less coily
and the fire will keep ya warm.
Vehicle: SJ80
Post Posted: Tue Jul 05, 2011 9:49 am
Have you fixed your car yet?
Post Posted: Tue Jul 05, 2011 9:53 am
:no: :no: Why do you ask?
Vehicle: SJ80
Post Posted: Tue Jul 05, 2011 10:01 am
I know it's more than likely to be the earth (as mentioned previously), but if it turns out it isn't, I have a spare coily cluster you could use for trouble shooting.
unless of course steaky's fix has been used :lol:
Post Posted: Tue Jul 05, 2011 10:11 am
I made a proper earth lead up at work yesterday....you have no idea how hard it is to find cable that small at work :lol:
Vehicle: SJ80
Post Posted: Tue Jul 05, 2011 10:22 am
What do you mean? You've got heaps of trucks at work :wink:
Post Posted: Tue Jul 05, 2011 10:25 am
By made....I meant found when one of our trucks had a flat battery and an auto lec left it on the side of the truck :lol: It's even blue to match the car :P
Vehicle: SJ80
Post Posted: Tue Jul 05, 2011 10:27 am
Nice, that's along the same lines I was thinking.
Post Posted: Tue Jul 05, 2011 10:39 am
I didn't find a bottle of motivation though....it will find it's way on there one day :lol:
Post Posted: Tue Jul 05, 2011 11:50 am
1 less coily
bahahha
Post Posted: Tue Jul 05, 2011 12:18 pm
1 less coily
bahahha
I'll bring the marsh mellow's
 Profile YIM
Post Posted: Tue Jul 05, 2011 7:01 pm
jimbo_jones wrote:
1 less coily
Bahahah
They would be tainted with coily flavour though :roll:
Users browsing this forum: Google [Bot] and 798 guests
