It is currently Mon Sep 21, 2026 7:20 am
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sun Mar 10, 2019 4:27 pm
First test drive after my rollover and l have transfer issues
No high two drive
No hi or low drive to front diff
Any thoughts before l go diving in
And yes front hubs locked in
Post Posted: Mon Mar 11, 2019 7:44 am
pull the stick out and check the bush
Post Posted: Mon Mar 11, 2019 7:42 pm
Bush was ok but had the slides lined up to the rear not forward when l put the stick in. What was l thinking
Post Posted: Tue Mar 12, 2019 10:10 am
burls wrote:
No high two drive
Might need some more detail here.
No high 2 drive? So when it’s in 2wd it doesn’t drive at all? So no drive to the front (which you’d expect) or rear?
When it’s in high or low 4 it drives from the rear but not the front?
Edit: sorry I just reread this post
So does that mean you’ve fixed it?
Post Posted: Tue Mar 19, 2019 6:22 am
Yes fixed
The problem was when l lined up the selector slides before putting the shifter in, l had them both in the rear position not the forward position. Just not thinking when doing the reassembly. Had me stumped for a bit
Users browsing this forum: No registered users and 196 guests
