It is currently Fri Jul 31, 2026 4:42 pm
Vehicle: Sj413k,35" silverstones
Post Posted: Fri Jul 01, 2011 3:04 am
:helloo: i have a sierra/samurai and i need to know if a stock clutch will handle 32" tires?
i have just put a standard clutchpro clutch in. will it handle them ok or will i need lower ratio gears? im going to put in gears at some point but i cant afford them at the moment but i still would like to run the 32"s. i only would run them when im off road as ive got standard tires as well
advice/help please
albie
Post Posted: Fri Jul 01, 2011 3:07 am
What type of zook?
Post Posted: Fri Jul 01, 2011 3:09 am
What type of zook?
oops my bad 1989 samurai/ or sierra in your country.
Post Posted: Fri Jul 01, 2011 3:11 am
It will handle the 32's onroad, But its going to be a slow dog with the 1.3..
Don't take it offroad, good way to cook a new clutch.
Get the gears asap or run stockers till you do.
Post Posted: Fri Jul 01, 2011 3:14 am
thanks
will a sj1410 t case and vit diff gears be enough? i dont do rocks so i dont need a real low crawl.
Post Posted: Fri Jul 01, 2011 3:18 am
Gearing ! 5.1 Transgears should solve ur problems :) and 5.1 isnt to low that u crawling around the place
Post Posted: Fri Jul 01, 2011 3:19 am
thanks
That would be a good start.
Post Posted: Sat Jul 02, 2011 11:54 pm
i have just measured the tires again and because they are worn down a bit they measure just under 31". will i still be able to use them offroad with out gearing? will the clutch be ok
Post Posted: Sun Jul 03, 2011 1:46 am
I ran 31" Simex with standard 3.7 diffs and a 1L transfer. Far from impressive but it coped. You just find yourself using lower gears and the right foot a lot more.
Users browsing this forum: No registered users and 381 guests
