It is currently Thu Oct 01, 2026 6:39 am
Post Posted: Sun Jul 10, 2011 1:19 am
hey guys just got a 1990 sierra and there is no clutch left can some1 post up a link to a good clutch install i had a look but cant find any
if u drive a loud toyota ute u drink rum
Post Posted: Sun Jul 10, 2011 1:28 am
Pretty simple. Remove gearstick, undo wiring, remove jack shaft and front driveshaft, undo bellhousing bolts and pull gearbox back. Roll box on it's side and drop out front first. Replace clutch kit and have flywheel machined. Then reverse order
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sun Jul 10, 2011 2:30 am
take engine and gearbox out, so much easyier
95 Sierra SJ70 TinTop
Post Posted: Sun Jul 10, 2011 2:57 am
tys for the aswers
Post Posted: Sun Jul 10, 2011 2:59 am
Nooooooooooo...... why do it the hard way if you don't have to?
Vehicle: 4wd
Post Posted: Sun Jul 10, 2011 3:05 am
Whilst you have the box out replace the engine rear main, and box input and rear seals.
Watch out or you'll get sued.
Post Posted: Mon Jul 11, 2011 7:09 am
Scrawn wrote:
Pretty simple. Remove gearstick, undo wiring,Drain oil, remove jack shaft and front driveshaft, undo bellhousing bolts and pull gearbox back. Roll box on it's side and drop out front first. Replace clutch kit and have flywheel machined. Then reverse order
Missed a bit...
Post Posted: Mon Jul 11, 2011 7:32 am
steak_knife wrote:
Missed a bit...
That bit does itself.... :lol:
I want my old sig back :(
Post Posted: Mon Jul 11, 2011 7:33 am
steak_knife wrote:
Missed a bit...
Oil drains out the back and runs down your arm as you're struggling to get the box out :roll: :lol:
Users browsing this forum: No registered users and 135 guests
