It is currently Thu Jul 30, 2026 11:01 pm
Post Posted: Tue Jul 05, 2011 5:14 am
hey guys did a quick search but mostly jeep flares forsale and want threads and ive bought some jeep flares just want some ideas on how you guys attatched them preferably without having to drill into my panels if possible
cheers luke
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Tue Jul 05, 2011 5:21 am
You won't avoid drilling.
Post Posted: Tue Jul 05, 2011 5:25 am
You are joking aren't you?
I use nutserts and 6mm stainless button head cap screws for that sort of job.
I guess you could try VHB double sided tape, but If it doesn't work they are going to fly off, and if it does work I reckon you'll take the paint off the car if you try and remove them.
I assume if you don't want to drill holes, you won't be cutting the guards under the flares either, in which case jeep flares look terrible - you can see far too much of the original wheelarch underneath them.
If you don't want to drill holes then surely you also don't want to drill the spotwelds out that hold the stock WT flare mounting flange to the body? Any flare is going to look craptastic with the stock flare mount flange visible under it.
Steve
Post Posted: Tue Jul 05, 2011 5:42 am
yeh i didnt think there was a way of avoiding it guess im going to have to then ay cheers for that
Post Posted: Tue Jul 05, 2011 6:52 am
Sicaflex!!!! :roll:
:helloo:
Post Posted: Tue Jul 05, 2011 8:50 am
6inch tec screws luke.
Vehicle: 6.5s, gti, 31 extremes
Post Posted: Tue Jul 05, 2011 9:35 am
Bluetack for the win Luke or maybe u could just use the spare bolts from ur gear box cover, u kno the one u don't use!!!!! Lol
Twincam coiler, rocktoy, 6.5s, lift, 31 extremes
Post Posted: Tue Jul 05, 2011 9:47 am
nic....
:thefinger:
Post Posted: Tue Jul 05, 2011 10:10 pm
Hey g wagon, how much of the guard in the wheel well shows with the jeep flares if you don't cut the guards.
Do you have any pics?
Post Posted: Tue Jul 05, 2011 11:59 pm
Fawking heaps, but it depends a bit on they are mounted, how much lift is in the car, the colour of the car, and how much tyre it's running.
These photos of a rear flare look pretty good, but it's a bit of a trick of very little spring lift, a big tyre, and a deep shadow. I run these currently with a 9/34's and they look craptastic. f you look closely at the side on view, you can just see the line of the stock wheelarch inside the flare. I can't stand it.
With a heavily cut guard they are OK (although I think the lines are all wrong for a sierra), and I think I'll be running them on my next build because the calmini flares aren't wide enough.
Here is a front TJ flare with some more light falling on it. I don't think this is a good look.
Post Posted: Wed Jul 06, 2011 12:15 am
I'll got 30/9.5 with 2 spring lift, 2 inch body
Car will be dark blue
I want the flare mount as low as possible
lower then the tj front flare of yours
I would like to use the DBOR flare or calmini because there the shape of the wheel arch, but are to
The jeep flare nd bushwacker flare would be okay but the both for jeeps wheel arches
So not sure what way to go
Post Posted: Wed Jul 06, 2011 12:22 am
They will look terrible with such a small tyre.
You can't really mount a front TJ flare lower than in my photo because then the leading edge extends past the front of the car. It's a bit hard to explain, but in that photo you'll notice the flare is distorted - you have to bend the front flare so it clears the door. they are really a terrible option.
In fact, the TJ front flare almost works better on the back of a sierra back-to-front (I did say "almost")
Rears are the only way to go, but it think you will find them too wide for your tyre size, and that makes them look very bulky and draws attention to them. There's no reason to ruin the look of the car for tyre coverage for your application.
For your tyre size the calmini flare is perfect.
With 31's
With GV rims and 9.5" wide swampers.
Steve
Post Posted: Wed Jul 06, 2011 1:12 am
Okay well look like its Calmini flare I'll be getting
they hard to get at all?
I need them before next months if possible
Post Posted: Wed Jul 06, 2011 1:17 am
yep, most likely they'll be out of stock....
get the DBOR flares.
Post Posted: Wed Jul 06, 2011 1:19 am
http://www.doubleblackoffroad.com/main.php
Contact them. The flares are not on their website though, so don't bother looking for them.
Post Posted: Wed Jul 06, 2011 1:28 am
I contacted calmini waiting on reply
No way I'll be spending $540 for DBOR flares
If I need them in a hurry I'll lash out nd spend the $540 they quoted me
Post Posted: Wed Jul 06, 2011 1:46 am
I'll spell it out more clearly.
I did say I bet calmini will say their flares are "on backorder"
This is my understanding of the facts.
Calmini flares were produced to order for Calmini by a company in Rowville, Victoria. Due to some dispute with Calmini, that guy made some flares off of calmini's moulds and sold them to guys in Vic.
After a prolonged period, the moulds were sold to another urethane company in Melbourne, (Boss products?) who made them in the "unbreakable" urethane grade and sold them out of their factory for some time, but were looking for a distributor as they didn't want to deal with the public.
DBOR took up the distributorship.
So, as I understand it, the DBOR flares ARE calmini flares - they are made from calmini's moulds (and they have "calmini" and the calmini part # moulded into them), which calmini don't own any more because of the dispute with the Rowville based manufacturer.
So, I think you will find the Calmini flares as "on backorder" which is code for "don't exist"
Whilst you're at it, ask Calmini about 5.83 vitara diff gears- they have been "on backorder" for about 5 years due to a similar dispute with Richmond gear in the US.
If Calmini have had some more moulds made and do have flares to sell,
A) they have two agents in Australia, they will direct you to them. They are on their website. If you are from a country on their site with a dealer, they will not sell to you.
B) If you find them through a US agent that will sell to you, get a shipping quote. Flares are bulky - I imagine the difference in retail price will be absorbed by shipping
C) Unless they have changed the grade of urethane, they are shit and will shatter. I know this because I have had some made from the original grade of urethane. They split if you look at them funny.
It's your money though - go crazy.
Post Posted: Wed Jul 06, 2011 1:48 am
:rofl: 5.83:1 diff gears = unicorn
Post Posted: Wed Jul 06, 2011 2:02 am
I just can't see myself spending that much money on flares
I don't care how it looks I just want my tyres covered
I'll just get some jeep flares I think
Post Posted: Wed Jul 06, 2011 2:08 am
Bunnings edging? Jeep flares (fronts especially) look like a gang raped asshole, and make baby jebus cry. :cry:
Post Posted: Wed Jul 06, 2011 2:09 am
If thats the case go get yourself some garden edging with the wire reinforcement from bunnings or clark rubber. Cheapest way out.
Post Posted: Wed Jul 06, 2011 2:20 am
X2.
Jeep flares aren't that cheap either. I only use them because they are wider than the calmini flares.
If someone made some moulds from the Bushwacker flares and made them in the same urethane grade as the BDOR flares they'd be on a winner.
Post Posted: Wed Jul 06, 2011 2:50 am
I don't want no garden edging shit been there done that
Garden edging is more then shit it's horrible
Exspecialy 100mm flate wide rubber sticking out the side
I want a one piece flare that will cover my tires in any way there is
Not flare plus garden edging
$540 Is really that much considering how much I've spent
BDOR flare Ordering time I guess
Post Posted: Wed Jul 06, 2011 5:08 am
A quick note about jeep flares.
These are the so called "unbreakable" Jeep flares from BDOR.
They are clearly not "unbreakable"
because jeep flares have straight edges and corners, they're easier to tear than the Calmini style flares, where the force is better distributed.
They have a number of big tears and splits in them
I'll admit these have been jammed very hard against banks, but these are the same tracks that are being driven with BDOR calmini flares and they are coping fine.
The shape of the BDOR Calmini flares makes them way more durable.
Post Posted: Wed Jul 06, 2011 5:14 am
Well they must have changed their compound recently because mine are cracked through the flange, and they haven't even been fitted yet. And my mate ( charlie13 on AZ ) has a set that he recieved 3 weeks late that are fucked from one end to the other. I'll try and get some pics.
Post Posted: Wed Jul 06, 2011 5:26 am
I've sort of heard this but haven't had it confirmed. We haven't bought any new ones for a while so maybe they have changed compound/quality control/supplier?
Honestly, the abuse I've seen them cop and bounce back is amazing - we've had them totally flat against the panels. Jamming them between the tyre and a bank has pulled them off though... but everything has limits - but the flare has been fine, it's just pulled the rivets through.
Users browsing this forum: No registered users and 371 guests
