It is currently Sat Oct 03, 2026 8:47 am
Vehicle: 92 Suzuki Sierra
Post Posted: Sat Jul 09, 2011 7:06 am
Been battling a problem for the last two weeks.
When i turn on the headlights it kills the stop light fuse and the interior lights don't work (or the dashlights either) It also kills the digital dash clock, which resets when i turn off the headlights
When in this 'mode' the highbeem light stays on even knowing its on low beam or when i use the brakes it flashes the highbeam light.
Last week tried replacing the indicator stalk cluster AND the instrument cluster. Found a dead earth (ripped out) going from the chassis to the body. I soldered it back on and it appeared to all be working perfectly whilst stationary, even if i used my old original indicator and instrument clusters. Put it all back into its place. Started the car and it lasted half a block before blowing again.
Have since double checked the rear earth, replaced the earth from the battery to the car body (actually added a 2nd wire) Still blowing fuses and depriving me of stoplights, interior light and dashlights.
All other electrics appear working fine (radio, lighter, fan, heater, reverse and indicators etc)
-Santos
Post Posted: Sat Jul 09, 2011 7:17 am
fitted an aftermarket cd player lately??
Post Posted: Sat Jul 09, 2011 7:23 am
not lately, about 3 or 4 years ago... the wiring was just hastily twisted in... been working since
-Santos
Post Posted: Sat Jul 09, 2011 9:30 am
youve got a short in your tail lights or parkers circuit or dah light circuit :)
I put my money on the tail light circuit
Post Posted: Sat Jul 09, 2011 9:31 am
x2
Ended up being muddy waterey shit in behind my talight globe. cleaned it out and wd-40'd it. good as new ever since.
Vehicle: 1995 Sierra 1.3
Post Posted: Sat Jul 09, 2011 11:33 am
x2
X3 I had the exact systems you described. Turned out it was because of a cracked tail light cover. Water and moisture diddled the connection on the contacts for the tail light globe. Changed globe and solved problem for the short term. It reoccured so I replaced the whole assembly. All good now.
Post Posted: Sat Jul 09, 2011 11:44 am
funny enough i have had a smashed in rear bar for 2 +yrs now... never a problem. Finally got round to changing it last month... used the old assembly
Also replaced one globe.
will dig out a spare set and see if it fixes it in the morning :)
While i'm at it i'll look into waterproofing the sucker
-Santos
Post Posted: Sat Jul 09, 2011 11:48 am
Try cleaning the socket out and seeing if it is the issue.
Post Posted: Sat Jul 09, 2011 12:13 pm
i think i know which side is the culprit..
now if only i could remember where all the dumped cars are that i drove past in my area.... i need fuses :)
-Santos
Post Posted: Sun Jul 10, 2011 10:00 am
Replaced rear tailight assembly with a spare one from the shed. All fixed now. Cheers guys
-Santos
Post Posted: Thu Jul 14, 2011 3:01 am
Grrrr!
Today i was cleaning out the garage and decided to test a headlight bulb that was on the shelf.
It worked then stopped working, i flashed the highbeam and it worked.
Put old bulb in still no low beam. I now have no low beam. Checked fuses and dash lights are working..
any ideas?
*sigh*
-Santos
Post Posted: Thu Jul 14, 2011 3:54 am
unplugged and replugged. All good
-Santos
Users browsing this forum: No registered users and 183 guests
