| What battery to put in my vit http://auszookers.com/forum/viewtopic.php?f=5&t=23737 |
| Author: | got_bar_work [ Mon Jul 11, 2011 1:30 am ] |
| Post subject: | What battery to put in my vit |
Hi I have a 91 lwb vit with ds battery mount I need to find the most powerful battery that will fit in the STD tray It has a ameron battery in it now but it has died Not bad as it is over 7 years old Was thinking of getting the same one but wanted to know what other batteries people are running Ps it has to be sealed I will never run wet cell batteries again |
| Author: | Santos [ Mon Jul 11, 2011 2:44 am ] |
| Post subject: | Re: What battery to put in my vit |
just food for thought, it doesn't take much to kick over a vit motor. Rather than getting a single big one get two smal ones and run them in parrallel. If one dies you still got the other I am considering fabbing 3 12v 20aH sealed batteries in parralel. just trying to find a 3rd one cheap (got two for free at the tip which have been holding charge for the last 2 years) |
| Author: | got_bar_work [ Mon Jul 11, 2011 3:45 am ] |
It's the 12000 pound winch that can draw 400 amps that's the problem I also have to get a new 40 amp deepcycle for the pass side The stupid air intake is in such a stupid spot If it ran straight instead of having the bends in it u could fit a heaps bigger batt in there |
| Author: | remydog05 [ Mon Jul 11, 2011 4:04 am ] |
Just get a good optima They fit in the standard tray if you get the right one. Google there website or ask Dank |
| Author: | stocker [ Mon Jul 11, 2011 4:53 am ] |
got_bar_work wrote: It's the 12000 pound winch that can draw 400 amps that's the problem
I also have to get a new 40 amp deepcycle for the pass side The stupid air intake is in such a stupid spot If it ran straight instead of having the bends in it u could fit a heaps bigger batt in there There is a solution to that
I run a Amaron Calcium battery, its great. |
| Author: | DMAC [ Mon Jul 11, 2011 7:23 am ] |
remydog05 wrote: Just get a good optima
They fit in the standard tray if you get the right one. Google there website or ask Dank http://www.batteriesdirect.com.au/shop/ ... ecial.html Batteries Direct have a special on at the moment. Just picked up an Optima Blue top 34M for $275 delivered. Been using the same battery in my SWB with a 12000lb winch for 2 1/2 years no worries. Fits staight in with no mods so should do the same for a Vit. |
| Author: | Santos [ Mon Jul 11, 2011 9:42 am ] |
stocker wrote: got_bar_work wrote: It's the 12000 pound winch that can draw 400 amps that's the problem I also have to get a new 40 amp deepcycle for the pass side The stupid air intake is in such a stupid spot If it ran straight instead of having the bends in it u could fit a heaps bigger batt in there There is a solution to that I run a Amaron Calcium battery, its great. OR Rerout the intake
| Author: | stocker [ Mon Jul 11, 2011 9:51 am ] |
hahaha, thanks captain obvious |
| Author: | holden26 [ Mon Jul 11, 2011 10:50 am ] |
I fit a mf75d23l in my sierra using the standard battery tray. Should be able to fit one in a vit without any dramas |
| Author: | Polar_Bear [ Mon Jul 11, 2011 12:14 pm ] |
I managed to squeeze In a n70zz in my lwb vit engine bay...just 710cca
| Author: | sogone [ Thu Aug 04, 2011 11:25 pm ] |
Post dig, But are those optimas the beez kneez? Would the standard altenator be able to supply enough power to the battery whilst using something like a 9000pound winch with the head lights on? |
| Author: | Poita [ Fri Aug 05, 2011 3:27 am ] |
I had a Optima Yellow Top D34 in my magna with a 1.5kW sound system and it coped no worries. I am in the process of installing a D51 into the Vitara and upgrading the cabling. For a small battery it packs a lot of punch... 41Ah, 500A CCA, 625A MCA |
| Author: | sogone [ Fri Aug 05, 2011 3:45 am ] |
The specs on the blue top 34M look alright. |
| Author: | got_bar_work [ Fri Aug 05, 2011 6:31 am ] |
I ended up getting to odyssey extreams as I got them real cheap I now have 1140 cca out of the 2 small batteries so that should be more then enough Looking at the measurements on the optima spec sheet I didn't think they would fit in the tray |
