It is currently Wed Oct 14, 2026 12:47 am
Post Posted: Sat Jun 28, 2008 2:13 am
On a stock Suzy, Im trying to get a measurement from the bottom of the bumpstop to the top of the diff.. Both front and rear..Can anyone help?? :?
Im trying to see if my spring combo has lifted suzy from stock...
Thanks :D
Post Posted: Sat Jun 28, 2008 12:41 pm
just went out and had a look (bloody cold). 55mm front and 60 mm back from the bottom of the bump stop to the top of the diff but they are the std springs from new i'd say so would of sagged a bit.
what is the car sitting at?
Post Posted: Sat Jun 28, 2008 2:46 pm
Ah yes cold in canberra, Cold ere too! Will be down there in 2 weeks!
Back to topic*
Lh side Rh side
Front-65 Front-55
Rear-60 Rear-60
So if i swapped the front spring sides it will probably level out with me driving...
lesspostingmorewheeling
Post Posted: Sat Jun 28, 2008 7:55 pm
i thought mine was standard but its a bit higher :?
front 80mm
rear 90mm
Vehicle: '92 Sierra
Post Posted: Sat Jun 28, 2008 10:01 pm
Lh side Rh side
Front-65 Front-55
Rear-60 Rear-60
If Bretts measure of standard height is right that means your running 33s with only a 2 inch body lift and some shackles clearing them. That can't be right. :?
Post Posted: Sat Jun 28, 2008 11:36 pm
2" bl and 33"s (really 32's) Stock ride height in springs and shackles, stock bumps!! Major front guard(front lip)scrubbage due to diff far too forward, and springs too soft which makes it bottom out over the slightest divot in the dirt, Beautiful on road.. Working that out..
Post Posted: Sun Jun 29, 2008 1:14 am
the car i look at is 100% stock.
bluesuzy should clear his wheels with a body lift because he has moved his front diff forward and his rear diff back if i remember right?
how does the set up flex? how many mm between the diff and bumpstop when flexed?
Post Posted: Sun Jun 29, 2008 3:33 am
im yet to test (measure)flex on flat dropouts, Rampups are no good. :?
+ i need flex with no scrubbing...Scrubbing will be reducing my flex :cry:
Post Posted: Sun Jun 29, 2008 12:48 pm
Hybrid wrote:
Lh side Rh side
Front-65 Front-55
Rear-60 Rear-60
It might be, he said they only measure 32". Mine measure 31" and I have only 2" springs, no bodylift, no shackle lift. I'm not surprised he is having problems with tyre rub though, mine does the same thing when crossed up. A little grinder love and it'd be all good.
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sun May 23, 2010 6:28 am
can anyone tell me what is the bump stop measurements should be or are with a 2 inch suspension lift
Post Posted: Sun May 23, 2010 6:49 am
Try adding 50mm/2" from Brett' s measurements?
Post Posted: Sun May 23, 2010 7:45 am
Yeah I could of done that,
But unless Brett's is with new springs it will not be a true measurement. Has anyone who has done a spring lift and measured this?
Post Posted: Sun May 23, 2010 8:15 am
No one is going to have a definate mm. As there is too many differences!
Different Makes of 2" Springs
Different Ages
Different Conditions
So if its over 100mm. She's lifted 2"
If your front springs are flat, Thats standard.
Users browsing this forum: Google [Bot] and 221 guests
