http://auszookers.com/forum/
Jimny Gearbox ( will a sierra one work)
http://auszookers.com/forum/viewtopic.php?f=5&t=23758
Author:  ianscott2003 [ Mon Jul 11, 2011 9:27 am ]
Post subject:  Jimny Gearbox ( will a sierra one work)
Blew up my gearbox. Wondering if a sierra one is the same??
Author:  89_tintop [ Mon Jul 11, 2011 10:30 am ]
Post subject:  Re: Jimny Gearbox ( will a sierra one work)
Will bolt up if you have a g13 engine... Bit am unsure if the shifter will line up with hole in the floor and also whether the jackshaft will fit.
Author:  joeblow [ Mon Jul 11, 2011 10:34 am ]
nope.
Author:  ianscott2003 [ Mon Jul 11, 2011 10:40 am ]
My car hit a bump and lost all drive. No 4wd or 2wd. Goes into gears but nothing working. I checked it isnt spinning the transfer shaft. I assume it is the gearbox. Wouldnt be the clutch at all?
Author:  89_tintop [ Mon Jul 11, 2011 10:41 am ]
joeblow wrote:
nope.
By how much is it out?
Author:  ianscott2003 [ Mon Jul 11, 2011 10:42 am ]
It is like the car is in neutral.
Author:  89_tintop [ Mon Jul 11, 2011 10:50 am ]
doesnt sound like a gearbox problem to me
Author:  ianscott2003 [ Mon Jul 11, 2011 10:51 am ]
Would it more likely be a blown clutch?
Author:  Jasen [ Mon Jul 11, 2011 9:12 pm ]
Is ur transfer case in neutral?
Author:  kirstyandgrace [ Mon Jul 11, 2011 10:00 pm ]
I would look at this first ^^^
Author:  FHA57 [ Tue Jul 12, 2011 12:19 am ]
sounds like a transfer case problem if its in neatral and u can still put ur gearbox into gears and it wont go does i6t make any noises or is it just not in gear?
Author:  FHA57 [ Tue Jul 12, 2011 12:20 am ]
if it was a fkd clutch it would smell like shit wen u tryn drive lol and would slip like a bitch
Author:  joe5701 [ Tue Jul 12, 2011 9:55 am ]
I checked it isnt spinning the transfer shaft.[/quote]
maybe torn the center out of the clutch plate?????????
Author:  HarryHoudini [ Tue Jul 12, 2011 10:10 am ]
Yep,or broken layshaft(or whatever the main shaft into the g/box is called these days).
