It is currently Sat Oct 03, 2026 1:10 am
Vehicle: Jimny, Lifted on 30's
Post Posted: Wed Jul 13, 2011 3:48 am
hey guys just have a few quick questions to run by youse, i am getting my new tyres fitted this friday and have a few quick things to questions.
I have a set of 4 15x7 inch sunnies with 0 offset and they sit fly dick close to the steering arms.. do any jimny owners have this problem, is it a problem ?
Also i have a steering wobble already around 70->80 kmh by increasing the width of the rim will that also make the wobble worse?
Should i just fit them to the standard jimny rims and not worry about unsing the sunnys.
Thanks guys your advice would be very helpfulL! Mubby.
:lol:
Post Posted: Wed Jul 13, 2011 4:06 am
what size tyre are you going to run? you can run a 235/75 on a 5.5 rim (just).
Post Posted: Wed Jul 13, 2011 4:24 am
im only running 215's its just that i have these new sunnies laying around so if i can use them i would but if its illogical to have them on when they sit so close to the steering arms i wont use them. ?
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Wed Jul 13, 2011 4:33 am
i wouldnt use a 215/75 on a 15x7 personally... the 215's will fit the stock 5.5 rim perfectly.
Post Posted: Wed Jul 13, 2011 4:39 am
ok thanks for the advice i might just stick them on the suzuki steelies i got with the car, save the trouble.
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Wed Jul 13, 2011 5:20 am
Hey mate I have -13 off set sunnies and 235-75-15 muddies and I had wobbles with stockie on it and now the new ones there is no wobble. -13 just tucks in the guards and give her a wider stance.
if u don't get stuck u ain't trying hard enough
Post Posted: Wed Jul 13, 2011 8:00 am
15x7 0 off set you won't have any issue's :wink:
Post Posted: Wed Jul 13, 2011 8:06 am
are your rims like 2-3mm of hitting the steering arm? and if i ran 215;s at low pressure would i be likely to roll the tyre off the rim?
Post Posted: Wed Jul 13, 2011 8:08 am
I have -13's :wink: But another guy on here has 235's on 15x7's 0 offset and has no issue with what your talking about :?
Post Posted: Wed Jul 13, 2011 8:22 am
I hve 235-75-15 wit -13 with no lift and still have no proba with what ur talkn bout.
Users browsing this forum: No registered users and 136 guests
