It is currently Wed Oct 28, 2026 10:00 am
Post new topic Reply to topic  [ 76 posts ]  Go to page 1, 2, 3  Next
Post Posted: Wed Jul 13, 2011 1:05 pm
just a random thing i have noticed.
do all Suzuki 4's have the same exhaust note? i was just looking at ataris vid and his s j20a and it sounds identical to my g13b that sounds identical to my old g13a... is it in the length of the exhaust? whats with it? just a interesting thing i have noticed! its a great sound that is diffrent to all other 4's that i have herd.
Post Posted: Wed Jul 13, 2011 1:10 pm
:? MY m13a sounds nothing like the 'g' series motor's.
Post Posted: Wed Jul 13, 2011 1:12 pm
i will add jazzors m13a sounds nothing like that. so m series aside......
i just find it strange that they can have a completely different valve set up but still get the same note...
also 11evl's buggie G16B had the same note when it was smashing the limmiter at tuff truck.
Post Posted: Wed Jul 13, 2011 1:13 pm
exhaust size maybe??
Post Posted: Wed Jul 13, 2011 1:16 pm
i was thinking that. size and route though the car...
some one must know!
i was expecting my g13b to sound like a ricer... but it sounds exactly the same as my g13a (different exhaust all together)
they are 2 very different motors, even the port angles are radically different
Post Posted: Wed Jul 13, 2011 1:17 pm
i take that as an insult phil, stinkin' coily driver :lol:
the muffler/cat makes the note, it just has that typical twin cam 4 cyl bark
ricers sound like ricers due to their shit idea of what a muffler is.
Post Posted: Wed Jul 13, 2011 1:22 pm
im not sure thats the case gus..
some engines have a "note" that no matter what u do its the engine note.. take the 4age.. u can here a twinky and id it from miles way when its sinning deep in to the 7***rpm range...
and most of the cars that make the "zook note" are g13a's carbi fed 8 valve singe cams.
Post Posted: Wed Jul 13, 2011 1:26 pm
You need a turbo Jonno
helloo
Post Posted: Wed Jul 13, 2011 1:33 pm
nah i have more than enough power for what i do. ask zook95.. his eyes lit up today when i puched it in the soft stuff.
Post Posted: Wed Jul 13, 2011 1:42 pm
atari's doesnt sound like any suzuki ive heard before :wink:
The vids dont do it justice and sounds nice in the dead of darkness when you can hear it going up gorilla snot hill :twisted:
Post Posted: Wed Jul 13, 2011 9:12 pm
Engine size and firing order are what makes the distinctive sound.... That is why SWB or LWB with or without extractors and/or cat conv all sound very similar.
Same reason 308 Holdens sound shit and 302 Ford (Windsors) sound sooo good. Firing order.
Post Posted: Wed Jul 13, 2011 9:56 pm
I don't know where you get that idea from, but it's a load of crap.
Most four cylinders have a 1-3-4-2 firing order, and if we used your "theory" a 1.3 BMC A-series would sound similar to 1.3 Suzuki G13B - they don't - they are both distinctly different.
As a second example - I have two Mitsubishi 4G63 engined vehicles here - same engine size, same firing order - and they sound NOTHING like one another.
For the third example - I have two Suzuki G13B engined vehicles, again same engine size, same firing order - and they too sound nothing like one another.
Strangely enough - at idle & low rpm operation - one of the G13B engined vehicles sounds a lot like one of the 4G63 engined vehicles - close enough that if you're not looking out the window, when they pull up in front of the house, you can't tell which is which from the sound.
Post Posted: Wed Jul 13, 2011 10:12 pm
You are entitled to your opinion... Even if I think it is wrong. :roll:
Vehicle: 2018 DMAX
Post Posted: Wed Jul 13, 2011 10:47 pm
I played round with different mufflers on my volvo in an attempt to change the note but it didn't really work. one muffler may have been quieter than another but the note was the same. The only thing that made a difference was a fart cannon, and that sounded like a bourbon bog after a hard night...
My G16b with single highflow muffler sounds great on the limiter, and sound slike any other G16b out there.
Post Posted: Wed Jul 13, 2011 11:36 pm
Put a big enough exhaust on a G16a Vitara and it can sound like a WRX at idle and low revs. Think some people need to get there ears checked. None of them sound alike if you listen.
All exhaust notes depend on the exhaust size, length, bends, mufflers and Manifolds. A J20 sounds completly different at 6500rpm compared to a G13Ba at the same revs.
Suzuki is my way of life.
Post Posted: Wed Jul 13, 2011 11:58 pm
i even gotto drive it :D :D :twisted:
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Thu Jul 14, 2011 12:23 am
Mean piston velocity combined with bore/stroke ratio as well as cam specs I believe.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Thu Jul 14, 2011 1:54 am
A previous bitza motor I built g13a bored block, g13b ported polished shaved head, flattop pistons, heavy camm ,ect ect sounded absaloutly nothing like the stock as g13b engine I replaced it with, using the same extractors and highflow cat exhaust, It had a hell of alot more of a bark and was border line probably to noisy after I swapped it out,
I personally think there is alot of factors into the SIERRA note as such, previously stated in other posts, engine size, exhaust size , length,bends, mufflers, catts, Extractors/standard exhaust manifold, injected, carby the list goes on,
All in all I u found 2 Suzuki"s that sounded identical, I'd love to hear it
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Vehicle: SJ80, SE416
Post Posted: Thu Jul 14, 2011 2:08 am
I have 2 sierras and a vitara. One is G13 and stock. One is G16 with 1.3 head and the other is G16. All carby. None sound even remotely close.
Post Posted: Thu Jul 14, 2011 2:11 am
:lol: hahahaha, there is definately no stealth mode @ 6000rpm but around town it can be quiet if i'm nice to it.
originally it was just a cat back 2.25" exhaust with a muffler, then after fitting a hi-flo metallic cat it changed the note slightly & now had a bit more bark to it. the coolest thing is it now makes the burbles you get from over run.
Post Posted: Thu Jul 14, 2011 2:12 am
i think jonno must be audioretared
Post Posted: Thu Jul 14, 2011 8:47 am
:no: not without a boxer engine it wont.
Post Posted: Thu Jul 14, 2011 8:57 am
My TT V6 300ZX sounded like a WRX. Had that meaty WRX throb. And no Boxer motor in sight :wink:
Vehicle: LWB Sierra & XL7
I think it's just a suzuki thing.. My old tinny which had a 7.5Hp zook outboard reminded me of the Vit.
'92 Vitara & Camper trailer
Post Posted: Thu Jul 14, 2011 9:28 am
For $20 you can buy a pod, stick it in the cig lighter tune ya radio, crank it up and have your zook sound like an F1, that'll make the neighbours look twice
:rofl: :rofl:
Post Posted: Thu Jul 14, 2011 11:17 am
My 92 vitara came with an aftermarket exhaust already on it and it sounds like shit. Can't hear my music and can't have a conversation. Hideous.
Got to fix it asap.
Vehicle: Daisy
Post Posted: Thu Jul 14, 2011 9:13 pm
Mine is stupidly loud inside the cab, and driving around in an undercover carpark or under a bridge, the thing sounds like the ricers that drive around with a milo tin on the exhaust...
It has character though!
Oh and on the highway you have a couple of different noises to choose from, exhaust noise, transfer whine, road noise or stereo!
Post Posted: Fri Jul 15, 2011 2:11 am
mine is short and throaty..... like the fumes come inside the cab and hurt my eyes and throat :(
Post Posted: Fri Jul 15, 2011 2:20 am
Haha, doesn't your exhaust finish just past your transfer?
Vehicle: Jeep
Post Posted: Fri Jul 15, 2011 8:26 am
Yeah i like the burbles too... sounds good when you are in 2nd and take your foot off the gas around 3500rpm... :roll: :lol:
Users browsing this forum: Google [Bot] and 347 guests
