It is currently Wed Oct 14, 2026 8:59 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
Post Posted: Wed Jul 20, 2011 10:05 am
Are you able to run half doors on the road in nsw for my 92 tin top
Vehicle: Sierra Ute '87 Sj70
Post Posted: Wed Jul 20, 2011 10:14 am
this might help
It's all coming together Armsup
i do at times.have been pulled up for rbts and what not n told they were cool so that means YES
lol i dont know really but i havent had dramas
Vehicle: LJ50V, SJ70
Post Posted: Wed Jul 20, 2011 10:32 am
What would be the benefit of having half doors on a hardtop?
Post Posted: Wed Jul 20, 2011 10:34 am
Same as a soft top. To have a better view outside the car?
Post Posted: Wed Jul 20, 2011 10:40 am
And more interior room of the door internals are gutted - 3" more knee room.
I can store heaps of stuff inside my 1/2 doors.
Vehicle: 03 Jimny
I would think they will be okay as long as you still have the mirror attached
Post Posted: Sat Jul 23, 2011 12:23 pm
hi i think as long as you have the intrution bar still in the door you will be fine.
KEEP ON ROLLING BABY!
Post Posted: Sat Jul 23, 2011 12:40 pm
Leafy sierras don't have intrusion bars.
Post Posted: Mon Jul 25, 2011 8:30 am
Had a chance to snap some pics of a couple of different 1/2 doors in the shed.
Mine:
This is inside. I'm sure you can imagine what the outside looks like.
that's 1" steam pipe as an intrusion bar. It's quite effective:
Here's how I did the latch - the square bar is the opener. It's easy to get to but impossible to accidently knock.
and here are CJ's. They were designed to work with stock Drover plastic door tops, hence the step back up at the rear of the door.
They use the stock door handle, remounted.
Either way, with the inside gutted like this, the car feels heaps roomier inside and the bottom of the door forms a neat pocket. I have an army pack bag and 2L soft canteen that sits in the driver's side door.
Vehicle: Clown Car..
Post Posted: Sun Jul 31, 2011 12:52 am
to add a couple of more pics to yet another door thread....
Drover half doors(same upright size as standard doors, minus the window support frame)
and some slightly modded standard doors, attacked with the grinder and shot with some speed holes :D
Post Posted: Sun Jul 31, 2011 1:39 am
Mine, using stock latch trimmed down and a pin in the top for release. (hence the slight rise in the back 80mm)
1.6mm sheet rolled on the other side for strength and no nasty edges. The top is just above my thighs when my bucket is in the car...stock mirrors re-located. No bog :lol:
Vehicle: Drover pickup turk
Post Posted: Wed Jan 22, 2014 3:31 pm
Hey Steve,
Did you cut down the latch at all? If yes, How so?
I'm about to cut some doors I've got here and plan to follow similar lines to yours.
I like the tuna here
Post Posted: Wed Jan 22, 2014 4:41 pm
A bit was cut off the top, the locking mechanism was gutted (but not the latch, it operates as per normal) and t he little bit of bar stock was welded to what was left of the tag the handle pulled on.
I'm a bit vague with the details as it was some time ago. When you cut the inside out the door it's easy enough to remove the latch and work out what can be stripped.
Post Posted: Wed Jan 22, 2014 6:57 pm
Plan of attack
Looking on the inside you can see where I plan to cut, The latch and other bits are JUST too high.
Cutting! Green line or Red line?
Green is looking like it will still be in the way, Red line will definitely clear but that means one less bolt holding the latch on.
After pulling the whole lot out and playing around with everything, It looks like this is the bit to attach a 'handle' to.
Post Posted: Wed Jan 22, 2014 7:06 pm
Thanks for the photos. I cut around the red line- I think I went straight through the middle of the bolt hole.
Yes I reckon you're right with the bit to weld the handle to
Post Posted: Wed Jan 22, 2014 7:16 pm
Did this for a member on here. He wanted mirrors and a latch For a roady sierra. Different but works.
Vehicle: Sj70 tintop
Post Posted: Wed Jan 22, 2014 8:34 pm
Mine:
what.. no speed holes??
disappointed steve.
Post Posted: Thu Jan 23, 2014 6:21 pm
Here's the latch cut down and removed of the unnecessary crap
Post Posted: Thu Jan 23, 2014 6:47 pm
If you have the skill's patience the handle can be cut/welded in underneath the latch and still work perfectly.
I dislike full height at the front of the too, I much prefer to follow the height the bonnet comes through at. But it also means relocating the mirror lower. Mirrors off a 1ltr work well - and use the angle of the bracket for the angle of the cut down to again keep all your lines parallel. (which coincedently is the same angle the top of your dash falls away at)
Post Posted: Tue Apr 29, 2014 3:18 pm
Here's what I came up with for the handle, I was originally going to do as Gwagen did on his doors, But played around with the stock handle to see if i could make it work.
Side on. It's in the right spot that I can open with my left or right hand and easily open it from the outside by reaching in.
Just cut the stock rod and re-bent it, Drilled the opening latch bit to put the rod in.
Post Posted: Tue Apr 29, 2014 4:13 pm
Nice.
Post Posted: Wed Apr 30, 2014 1:31 pm
I ha cut down 2 doors... Got is all working cut down the latch... I have left the inside of the door on though as I won't use it for stargaze because I hate things ratleing around! Haha
What would you guys recommend me to get for the tops? Is 2mm steel too much to weld to the stock tin can Zook material?
Post Posted: Wed Apr 30, 2014 2:35 pm
The RHS I used was 2mm, It was a pain in the arse to weld the panels to.
Post Posted: Wed Apr 30, 2014 2:50 pm
I can't really use rhs because the angles are all different! Ill wacka pic up
Post Posted: Wed Apr 30, 2014 4:08 pm
I have welded 1mm and 3mm onto zook panels with good results so it can be done!
Post Posted: Wed Apr 30, 2014 7:16 pm
You weld to the thicker stuff and invite the thinner stuff to the party.
These are 2mm top plates dimpled and a bit of 3" exhaust pipe for a cup holder.
Post Posted: Wed Apr 30, 2014 7:50 pm
That's exactly how I have cut mine! Cheers mate! I like the cup holder too!!!!
Post Posted: Wed Apr 30, 2014 7:57 pm
Its not a tight fit on a stubbie cooler, but its what we had lying around in the rush up to TT. Theres about an hour in making that door. They're off my Blue Sierra too haha
Post Posted: Wed Apr 30, 2014 8:15 pm
SierraDan wrote:
Mine are cut exactly the same as that too, Had no worries using RHS.
Users browsing this forum: No registered users and 326 guests
