http://auszookers.com/forum/
Threaded Eye Bolts
http://auszookers.com/forum/viewtopic.php?f=5&t=24089
Author:  Che [ Thu Jul 21, 2011 8:13 am ]
Post subject:  Threaded Eye Bolts
Anyone know where I can get a single threaded eye bolt such as this? I need one to lock my mixer ring and air box cap to my throttle body.
Specs needed - 3 to 4 mm thread, 7 cm long but can cut length to suit. Eye size can be worked around
No luck at two bolt shops I went to... where else could I try?
Author:  troopy [ Thu Jul 21, 2011 8:16 am ]
Post subject:  Re: Threaded Eye Bolts
You could try a bearing supply place and just get a female rod end in the size you need then screw in the required length bolt or threaded rod
Author:  TZAR [ Thu Jul 21, 2011 8:25 am ]
what about threaded rod and a wing nut?????
Author:  Teracis [ Thu Jul 21, 2011 8:33 am ]
You can get eye bolts separate to thread, just screw it on and weld it (or lock it with a locknut underneath)
Or just get some threaded rod and a bit of plate with an eye in it and weld the eye plate on the end?
Author:  Zook_Fan [ Thu Jul 21, 2011 8:38 am ]
You can get pretty similar at BCF, they are rated as well
Author:  Che [ Thu Jul 21, 2011 8:41 am ]
I need the eye bolt on one end to use as an anchor point, nothing that can rattle loose as it'll be virtually on top of the TB butterfly. I could get it welded I guess, but i'll try track down the part as seen above first.
Author:  TZAR [ Thu Jul 21, 2011 8:42 am ]
http://www.fastenersales.com.au/allthre ... -1115.html
M4 stainless rod 1 metre $3.96 + freight
Or go round and find some stainless wire they use for decking and grab the turnbuckle of that. Uncrew the threaded part from the turnbuckle and tada freebie
Author:  want33s [ Thu Jul 21, 2011 10:52 am ]
have you tried www.riggingshed.com.au ?
Author:  masterA [ Fri Jul 22, 2011 12:20 am ]
West Coast Fasteners - 9240 2750
Specialized Threaded Fasteners - 9418 6655
Hobson Fasteners - 9455 5489
Coventry Fasteners - 9350 3600
Jimmal Bolts - 9444 1895
Robertsons Lifting - 9451 1522
The Rigging Shed - 9494 5800
Specialised Lifting - 9434 1776
Hoisting Equipment Specialists (HESWA) - 9355 4218
One of them should be able to help you :)
Author:  shakes [ Fri Jul 22, 2011 12:27 am ]
you need...
- the eyelet
- the threaded rod
- nut to suit threaded rod.
Wind the nut onto the thread, dob the end of the thread with locktight, wind the eyelet on as far as it will go. Then tighten the nut back into the eyelet, it will not come undone. and be your easiest option. also for down the track if you for some reason need to replace it things will be easier to find.
Author:  Che [ Fri Jul 22, 2011 8:52 am ]
Done:
