It is currently Tue Oct 20, 2026 9:45 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2  Next
Post Posted: Sat Jul 23, 2011 4:00 pm
Hey guys.
I've now got a 40mm lift on my 2000 GV & I'm looking to put some new tyres on in the 245/70R16 size next week, I've been looking through the forum but couldn't find much information about that size on a G.V. Does anyone know if this size will be fine when it comes to fitting/rubbing? There's not many options in the 235/60R16 range & I don't want to go any skinny like 225 or that bit higher with 245's.
As far as I can see, with that size tyre I would like should make me appox 8kph out higher on the speedo, but a tyre dealer said I should be close to the proper posted speed limit as the current 235's are under speed?
Any advice appreciated, thanks
Paul
Post Posted: Sat Jul 23, 2011 10:03 pm
They are going to rub plenty. That's why you haven't seen much data on anyone running them. Clearance around the front edge of the rear wheelarch/door will become a big issue.
There's a reason everyone runs 225/75/16's - that's as much as can fit without having to do lots of guard work.
The 10mm loss of width isn't relevant to capability.
Vehicle: 02 GV
Post Posted: Sat Jul 23, 2011 10:33 pm
I run 235/70/16. only rub at full lock and only just. thats with 25mm spacers in the front.
on the back there is about 10mm clearence and thats with the rubber mud flap missing. I have 40mm springs and 50mm spacer.
I reckon that's as big as you can go without taking bits of plasitc off. i have a 02 gv.
Post Posted: Sat Jul 23, 2011 10:39 pm
I don't think it's the plastic that's the problem, it's the rear wheelarch, which is covered by the door. Opening that up requires lots of metalwork on the door and arch.
It's the same area that's the biggest problem on the 4 door vitara, but the guard starts out bigger on the vitara, so it's less of a restriction.
Post Posted: Sat Jul 23, 2011 11:59 pm
Ok thanks guys, that's interesting. One of the tyres I was looking at was the new Cooper AT3 in 245/70/16, because on the Bridgestone site they say the D694 don't come in LT construction on their website.
So are you guys saying it's the "width" of the 245's thats the problem not the the "70/75 height" that cuases the rubbing issues :? Thanks.
Paul
Post Posted: Sun Jul 24, 2011 12:15 am
I'm currently going through lots of different tyre compaines to see what they make in LT construction, one of the things I'm worried about is ***/75/16 tyres [75] putting my speedo to far out & needing a speedo correction kit.
Post Posted: Sun Jul 24, 2011 12:41 am
I use this tyre calculator alot when figuring out tyre sizes on different cars. http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
The 225/75 and 245/70 are only 6mm different in diameter
I cant see why a 245/70R16 wont fit. Yes it will rub a bit when offroading and at full lock.
Im planing of fitting some 31inch or equal size tyre on mine. just need to find another 2 to use as a trial set.
Post Posted: Sun Jul 24, 2011 12:50 am
Tombutt runs 245/70 r16 on his SV vitara. As G-wagen said, you have slightly less room, so any clearance issues will be compounded.
Are you against panelwork in general? Or just looking for the easiest option?
Post Posted: Sun Jul 24, 2011 2:38 am
If your going to run larger tyres then you should look at changing diff gears.
Post Posted: Sun Jul 24, 2011 3:22 am
Gregdixon has 245/70/16s on his GV
http://www.auszookers.com/index.php?nam ... ic&t=14655
My Grand Vitara
Post Posted: Sun Jul 24, 2011 3:56 am
Ok thanks guys, it's an interesting one, I just wouldn't mind a bit more upsize/lift from the stock 60 size tyre but without doing any body/panelwork or changing diff ratio's if possible. Plans for it's use is light & medium grade trips carrying some camping gear. Thanks.
Paul
Post Posted: Sun Jul 24, 2011 6:31 am
for starters what drive r u doing to need LT rated tyres if u r drive beach stuff and need the tyres to bag then go with a pasenger tyre but if u want a tyre for offf road then go LT rated tyre .
Coopers new AT3 is LT but in pasenger contructsion so will bag will. If ur car is a GV go with 235 70 r16 they will ride nicer than 225?75R16 due to this tyre being a soild LT tyre.
Post Posted: Sun Jul 24, 2011 7:20 am
Hi, no sand work, Lithgow districts mixed trail conditions mainly when offroad.
Post Posted: Sun Jul 24, 2011 7:37 am
ok if u can wait cooper r bring out more size in the new patterns such as the AT3 and the cooper ST maxx both tyre patterns r very quite to drive on do to fix a lot of then and r great looking tyres and the compound is great to if i was u i would contact ur dealer and get them to ring suplier and see when they will be availbe if they dont want to contact me on her and i can check for u and see when they r coming out .
they r trying to get rid of the stock of ATRS first and r bring more sizes in the cooper new product out soon .
Post Posted: Sun Jul 24, 2011 7:41 am
sorry that was fitted a lot of them and a 235/70 r16 is a nice tyre to drive on and will mould to rocks when running lower tyre presh better than 225/75r16
Post Posted: Sun Jul 24, 2011 8:23 am
Ok so for wanting a bit of tyre lift height from the "60" size stock tyre & having to do no or as little panel/body work as possible from rubbing & with the 40mm lift already I'm not wanting to do any spacer/body block lift or diff ratio changing - then, I should be looking at "235/70/16" & not 245/70/16 or 225/75/16.
I'll have to check to see what LT's are made in this size, I'm really open to all brands of tyres though if they'll do the job [Mainly Lithgow area stuff]
Sorry about the questions guy's - I haven't had the G.V for too long, so I appreciate all feedback, thanks.
Paul
Post Posted: Sun Jul 24, 2011 8:53 am
225/75R16 will fit and all you have to do is remove the mud flaps.
The tyre choice is totally up to you. find something you like and in your price range.
Post Posted: Sun Jul 24, 2011 8:57 am
I'm not worried by the price of the tyres, so that's cool & not really worried about the brand of AT - just worried about parting with the coin on the wrong size tyres.
It's all interesting information for me.
Vehicle: 2004 SQ625 GV
Post Posted: Sun Jul 24, 2011 10:14 am
You have the same gearing and clearance issues with 245's as you do with the 225's. If you want the wider tyre go for it. The 694 is getting canned and being replaced with 697 similar pattern though.
Post Posted: Sun Jul 24, 2011 2:37 pm
I hope to drop by my local tyre shop later today to get some quotes & see what's made in LT.
Post Posted: Thu Jul 28, 2011 12:51 pm
Hey guy's, I've got a quick question - what would give me less rubbing & less need to do any panel work etc out of these 2 sizes, thanks
225/75/16 or 245/70/16
Post Posted: Fri Jul 29, 2011 12:23 am
Looking at Cooper AT3 or D694 atm with those above sizes, not much made in LT in 235
Post Posted: Fri Jul 29, 2011 6:41 am
the 245v is 20mm wider in the tread and 6mm taller so it will rub more att full lock.
Use the tyre calculator below to compare tyre sizes.
Vehicle: Jeep
Post Posted: Fri Jul 29, 2011 8:33 am
Have you looked at Maxxis tyres, they do quite a few in LT235/16's !
The Maxxis site has more tyres, and tyre info than the aussie site -
http://www.maxxis.com/AutomobileLight-T ... k-SUV.aspx
I have the Bravo 771's on my GV in a LT225/70/16
But here is the Aussie one -
AT's
http://www.maxxistyres.com.au/tyres.php?cat=3
MT's
http://www.maxxistyres.com.au/tyres.php?cat=4
Vehicle: 2001 XL7
Post Posted: Sat Jul 30, 2011 4:13 am
Go a 245/70/16 in an all terrain or a 225/75/16 in a mud tyre
Post Posted: Sun Jul 31, 2011 4:00 pm
I read the 4WDAction article on AT tyres, the Yokohama AT-s sounds good but not avalible in LT [says tyre shops] , D694's don't read as good as I'd hope, Maxxis 700/771 not LT according to 2 different tyre shops, so the 225/75/16 Cooper AT3's are looking good at the moment :)
But I had Cooper ST's & STT's on my 100Series Cruiser before & they were crap - they chipped to the shithouse :oops:
When I get this tyre issue sorted out, I'll start a page in the rigs section.
Vehicle: Jeep
Post Posted: Sun Jul 31, 2011 4:58 pm
I read that too... but i would take it with a pinch of salt... as they are not very unbiased in their opinions/testing...
Dont know what tyre shop told you the Maxxis 700/771 is not available in LT, but they are telling you a BS story, i have LT225/70/16's on my GV !
I got mine from Bob Jane t-Marts, product code for them is - MAO12257066, and they were only $185 per tyre...
I do like the D694's, they were going to be my 2nd option, if i couldnt get the Maxxis, but they dont come in a LT for the GV, as far as i can see...
Post Posted: Sun Jul 31, 2011 7:37 pm
maxxis don't really have that good an all terrain those new st coopers we just got them coming through at work at the moment they look awesome chating to our supplier and he said they are way better than the old st really heavy tyre they are about 320 for a 265/75/16 and they have fixed the compound of the tyre meant to be way better than the old ones that used to go hard and do 150000
Vehicle: Jeep
Post Posted: Sun Jul 31, 2011 8:27 pm
I disagree about Maxxis AT's, mine have taken everything i have thrown at them, rocks, sand , and mud, and have performed very well, i have had them for nearly a year now, and they are only just showing any signs of wear, and for those on a limited budget, or want to save money, they are $140 cheaper then coopers... :D
Post Posted: Mon Aug 01, 2011 12:45 am
A guy at work has had the same D694's on for 120K and thats without the deeper tread volume and the dompulsory rotations of the coopers.
Users browsing this forum: Google Adsense [Bot] and 236 guests
