Joined: Sun Mar 28, 2010 10:30 pm Posts: 16 Location: Country NSW
Posted: Sun Jul 24, 2011 9:07 am
Hi guys,
My sierra has a problem with coolant leaking from what looks to be the pipe behind the water pump. Wondering if anyone has had a similar issue? Is this actually the pump or not? Whats the best method to fix?
O-ring that goes in the back of block were waterpump Bolts on
Get a new o-ring
suzooky87
Posted: Sun Jul 24, 2011 9:42 am
Well if it is comming out of the little hole just behind the pully, it is an indication that it needs replacing. As that is what the little hole is for. just double check it
Users browsing this forum: Google [Bot] and 197 guests
