| dash http://auszookers.com/forum/viewtopic.php?f=5&t=24197 |
| Author: | 4x4zook [ Sun Jul 24, 2011 12:29 pm ] |
| Post subject: | dash |
hi guys. trying to get my dash cluster out of my 92 swb sierra but i cant seem to work out how it pulls out of the dash. it wont go past the hazard light switch. any tips? do i haveto take the whole dash out just to remove the cluster? cheers |
| Author: | foolsp33d [ Sun Jul 24, 2011 12:41 pm ] |
| Post subject: | Re: dash |
wiggle wiggle.. then once its out, cut a small tab outta the bottom of the cluster for an easier re-fitment/removal next time... Dont want to cut it.. live with it being a tight awkward fit I believe is the consensus... |
| Author: | royce [ Sun Jul 24, 2011 8:45 pm ] |
2 bolts, undo the column and let it drop down a bit |
| Author: | Damo [ Sun Jul 24, 2011 10:10 pm ] |
foolsp33d wrote: wiggle wiggle.. then once its out, cut a small tab outta the bottom of the cluster for an easier re-fitment/removal next time...
Dont want to cut it.. live with it being a tight awkward fit I believe is the consensus... There is a better way Undo the 2 bolts that hold the steering column to the cross bar. You'll then be able to push the column down enough to get the cluster out.
Also remember there are 4 screws holding the cluster in, 2 countersunk ones on top of the dash and 2 screws undernear the cluster. |
| Author: | Gwagensteve [ Sun Jul 24, 2011 10:14 pm ] |
X3 to Dropping the column. Steve. |
