It is currently Thu Oct 08, 2026 4:23 pm
Post Posted: Tue Jul 26, 2011 9:57 am
Fellow Auszookers I have cunundrum
I want more flex (in the front) and a little more comfort out of my Vit. Was just wondering if changing the Calmini shocks to a set of OME 40mm lifted Ones would help??? or if anyone is running other brands, i know the Calmini Shocks are of Stock Length... hence the Spacers.
Any thoughts?
Stocker
Post Posted: Tue Jul 26, 2011 10:00 am
i run OME's + the calmini strut spacer & this combo works well for me, with the latest feedback on the OME struts I'd be buying Dobinsons.
Post Posted: Tue Jul 26, 2011 10:01 am
Buzbox will be able to help with the ride difference with the new dobinsons he has up front in his.
Post Posted: Tue Jul 26, 2011 10:02 am
Dobinsons are a bit cheaper too aren't they???
Have you had to put spring retainers in???
Stocker
Post Posted: Tue Jul 26, 2011 10:06 am
no retainers but i do run Flaggy Vit Fab 50mm bumpstop extensions in the front & 70mm ish Glenarm Eng rear bumpstops.
just for the $$$$ i'd be going the dobinsons.
Post Posted: Tue Jul 26, 2011 10:10 am
sweeet :) i will look at doing the same seeing as it seems to work.
cheers for the advice
Stocker
Post Posted: Tue Jul 26, 2011 10:13 am
pull the spring out of the front end, bolt in new strut... cycle suspension & measure for bumpstop length.
http://auszookers.com/index.php?name=Fo ... mpstop+diy
Users browsing this forum: No registered users and 160 guests
