It is currently Thu Oct 08, 2026 6:51 pm
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Tue Jul 26, 2011 11:50 am
Just inquiring if anyone has replaced the Rubber Mounting Bushes on the Helm Joint above the Rear Diff on a Vitara
What type of Bushes go in there.... They look very similar to your normal Shackle Bushes.....
rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Tue Jul 26, 2011 11:59 am
if your talking about the ball joint, it's a non serviceable item as far as I'm aware... but
can I please just say this & it's been shitting me for years, the standard Vitara does not run a HEIM joint, it uses a similar set up to a ball joint.... so many people get this part wrong, the Calmini kit uses a Rod End/Heim Joint/Rose Joint.
I blame ODA for having the incorrect info on his website.
Post Posted: Tue Jul 26, 2011 12:00 pm
Do you mean Heim joint? :?
This is a Heim Joint
You would need to fabricate a new upper a-frame to house one of these.
Post Posted: Tue Jul 26, 2011 12:24 pm
I'm not talking about the ball-joint end, but the other end, where it attaches to the cross member/chassis. The bushes where it swings from. These appear to be worn on mine.....
Post Posted: Tue Jul 26, 2011 12:26 pm
Pete... Do u have any of these made up. If so, would b greatly interested :wink:
A Arm bushes is what you're after, the calmini A Arm runs a shackle type bush, pretty sure the original ones are a press fit bonded rubber bush.
Post Posted: Tue Jul 26, 2011 12:29 pm
Cheers for that... U don't know where I can get one of those Calmini Arms only from ???
From what I've been told, u need to buy the whole kit.....
Post Posted: Tue Jul 26, 2011 12:36 pm
PM'd.
Post Posted: Tue Jul 26, 2011 9:10 pm
I have a full rear bush kit coming for my extended arms and new a arm that fatpuke has made me as I was over trying to replace those ball joint arms
Users browsing this forum: No registered users and 171 guests
