It is currently Tue Oct 13, 2026 8:11 am
Post Posted: Wed Jul 27, 2011 8:06 am
hi guys wont be long till i have my sierra up and running again :)
i need to know where to connect some hoses up to
1.does this inlet on the right of the water heater go to the thermostat housing?
Uploaded with ImageShack.us
2.where does this valve thingy for the water heater connect up to???
3.where does this hose connect up to? its the 2nd one from the front of the inlet manifold
4. Also, i have a plug from the old wiring. it came from a water temp sensor near the thermostat on the g13b. does that need to be hooked up anywhere? I have already connected up the baleno water sensor to the new wiring loom
hope to hear from u guys :)
Post Posted: Wed Jul 27, 2011 9:07 am
Hey mate. I'm about the same progress thru the conversion as you are.
Hope this helps
1. Water pump piping
2. Thermostat housing
3. Water pump piping
4. I used a 28mm water temp sensor adapter for this and kept it utilized for the temp on the dash, and used the baleno one for the ecu.
Let me know if there is anything else you need.
Adam
Post Posted: Wed Jul 27, 2011 9:13 am
Thanks heaps man! il be connecting them up tomorrow :)
about the water temp sensor: does that mean u installed 2 sensors into the thermostat housing ?
Post Posted: Wed Jul 27, 2011 9:18 am
Yeah it no. I'll upload a pic to show u
Post Posted: Wed Jul 27, 2011 9:21 am
Connected the baleno sender in the original location
And going to fit this in the return inlet hose
Post Posted: Wed Jul 27, 2011 9:32 am
i see what u mean now :) where did u get that from? looks nice and shiney
so when u say the return inlet hose does that mean ur connecting it between the thermostat housing and the radiator?
and how do u connect up the wire to it?
Post Posted: Wed Jul 27, 2011 9:38 am
Hi,
I did this conversion bout 6 months ago.
The baleno temp sender has 3 wires on it. On is the ground, one goes to the ECU, the remaining one will drive your existing temp guage.
I think it is the yellow/white wire on the temp connector that you will use for the temp guage. The LightGreen/Red is the wire that goes to the ECU.
For the heater hoses. I connected the one from the heater tap to the thermostat housing on the rear on the head. The other one connects to the end of a standard Sierra water pump outlet tube(large metal tube running from the rear of the water pump). The Throttle body heater tube also connects to water pump outlet tube just behind the water pump.
Hope this helps.
Post Posted: Wed Jul 27, 2011 11:26 pm
Yeah that's the one mate, thermostat housing to top radiator pipe.
With connecting it ill change the plug on the zook wiring harness i imagine.
Here is a link to the product.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWNX:IT
Now i have a question for you ;)
Where did you find the joiner for the radiator hoses? I've been looking everywhere.
Post Posted: Thu Jul 28, 2011 4:00 am
Ohhhh man I think I've connected my radiator pipes wrong. I connected the thermostat to the bottom of the radiator... I just sort of guessed it from a pic I saw from cairnszooks build thread. I couldnt really tell what way it was supposed to go.
I just used some random hose pieces I bought from precision auto spares. I joined them just using an off cut from
The baleno water pump pipe. Im using the sierra water pipe so I decided to cut a few bits off the baleno one. I'm also using a custom thermostat housing and swift thermostat cap made by bluesuzy.
Cheers heaps for the link. Il probably buy it. I'm going to see if running the wire into the baleno water temp sensor plug work first
Post Posted: Thu Jul 28, 2011 4:46 am
Sorry if i have confused you.
Check this out. Its what Ive used as reference
Post Posted: Thu Jul 28, 2011 5:06 am
yep ive done it wrong. wish i came across that diagram before i did the work
Users browsing this forum: No registered users and 209 guests
