It is currently Tue Oct 20, 2026 11:24 am
Post Posted: Fri Jul 29, 2011 9:06 am
92 vit, horn won't work damn it !
think its the horn relay, youd think iknew where it was but nooo idea.
Post Posted: Fri Jul 29, 2011 9:08 am
it's under the dash board somewhere, unplug the horns & hit the button a few times... you should hear it.
Post Posted: Fri Jul 29, 2011 9:16 am
yep cant hear it, so its rooted
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Fri Jul 29, 2011 9:24 am
I was doing this today. The only relay I could hear was the one
I'd just put in.
There's a wire that goes over the flexible joint on the steering column.
Have a close look at it.
Mine was corroded and was stopping my horn from working.
Cleaned it up and it's been fine ever since.
Post Posted: Fri Jul 29, 2011 9:26 am
awesome man thanks :)
Vehicle: Suzukiless these days..
Post Posted: Fri Jul 29, 2011 10:04 am
Check the metal box ontop of the steering collum, If you haven't got the dash out it is really hard to see, unless you have real small arms its hard to reach to.
goddamitmyspacebarsbrokenagain
Post Posted: Fri Jul 29, 2011 9:43 pm
On my vit the horn didnt work when I got it cos the wire in the horn button had come off its soldered spot, I just used a crimp and one of the screws to reconnect it, tis easy to check just pull the horn pad off
Users browsing this forum: No registered users and 392 guests
