http://auszookers.com/forum/
Wobble and steering damper swap
http://auszookers.com/forum/viewtopic.php?f=5&t=24352
Author:  krunchi [ Fri Jul 29, 2011 12:34 pm ]
Post subject:  Wobble and steering damper swap
Hi Guys,
I have a Rough Country steering Damper.
WIll i notice any difference is i replace it with a RTC tough dog damper?
Steering has some wobble and is a bit wandery at higher speed.
Car has been lifted and castor correction fitted.
Author:  monley [ Fri Jul 29, 2011 12:47 pm ]
Post subject:  Re: Wobble and steering damper swap
Yes! But it will not fix the issue, just cover up the problem more, but they are great off-road....
Author:  zooker [ Fri Jul 29, 2011 12:50 pm ]
A steering dampener will only mask the problem. Your better off spending the money resolving the issue of the wobble
- wheel balance
- buckled wheel
- wheel bearings
- kingpin bearings
- suspension bushes
- steering box
Author:  sbbunno [ Fri Jul 29, 2011 3:04 pm ]
I got Water in my tyres that i cant get out it is causin some wobbles.
Author:  SuziBlu [ Fri Jul 29, 2011 6:59 pm ]
Crikey, an there are no tyre dealers in WA who can take the tyre off and drain the water, making your car safe, bugger.
Author:  SuziBlu [ Fri Jul 29, 2011 7:00 pm ]
Author:  Damo [ Fri Jul 29, 2011 9:43 pm ]
- wheel balance
- buckled wheel
- wheel bearings
- kingpin bearings
- suspension bushes
- steering box
These are all relevant things to check when chasing a steering wobble, but one thing I don't hear people mention much is the knuckle scraper seals. In my own experience I have found that having freshly rebuilt knuckle assemblies makes a lot of difference.
If you check all your bearings, bushes rod ends etc and are still getting the wobble do a knuckle rebuild.
