It is currently Wed Oct 28, 2026 10:50 pm
Post Posted: Mon Aug 01, 2011 12:01 pm
did a search but couldnt find my answer
where is the best spot to put an aftermarket oil temp sender for an aftermarket gauge on a sierra 1.3
also what about the water temp sender?
both are electronic Autometer gauges with NPT fittings
Post Posted: Mon Aug 01, 2011 12:37 pm
I just screwed my water temp sensor into the stock sensor hole. Why bother having 2 water temp gauges :?
Or you can get an adaptor to go in the radiator hose, however I struggled to find one small enough for a zook hose.
You can get an adaptor to go between the oil filter and block to allow for the sensor.
Can find these adaptors here (and probably every other performance parts supplier)
http://www.crispmods.com/index.php?page ... t&Itemid=2
Member of C.O.R 4x4
Post Posted: Mon Aug 01, 2011 12:41 pm
cheers silly question but where is the water temp sensor located?
Post Posted: Mon Aug 01, 2011 12:47 pm
side of thermostat housing
Post Posted: Mon Aug 01, 2011 1:20 pm
If you can get a sensor that fits the stock sensor hole use it - if you use an adapter that goes in the radiator hose, leave the stock gauge in place - the new gauge will not indicate the engine temperature until the thermostat opens and a thermostat which fails closed may result in the engine overheating with no indication on the gauge.
Users browsing this forum: No registered users and 330 guests
