It is currently Wed Oct 07, 2026 11:19 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post Posted: Tue Aug 02, 2011 6:14 am
Hi guys,
I know this topic may have been covered before. However, I did search and did not find anything relating to my question. *only for sierras
So I am in the process of selecting my new lift. The car is a 1996 Suzuki Vitare SWB.
The only lift that seems to have good reviews is the Calmini 3" Super Articulation kit. Seeing as Fatzook's kit isn't ready and doesn't seem like it will be ready for a while, I believe this is the kit I will be ordering.
You can't rush perfection Pete :lol:
What I would like to know is would the 3" lift and a 2" body lift change my COG to a level where I will be at great risk of rolling?
Is 5" of lift too much in a SWB Vitara?
The general concensus is that the Calmini lift is too hard. I currently do not have a bull bar nor do I have a winch. With the combination of hard springs (which I assume would reduce the flex?) and the added height; would my car be at a greater risk of a topple?
I appriciate your time :helloo:
Post Posted: Tue Aug 02, 2011 6:17 am
isn't 5" of lift a no no in QLD?
Post Posted: Tue Aug 02, 2011 6:18 am
Vitaras are wide, even up that much they are still low so its not going to make it anymore tippy than a Hilux
but why do you need the lift? thats the important question, we should all know bigger isnt better by now
Post Posted: Tue Aug 02, 2011 6:30 am
Yeah mate. 2" body lift is legal. 3" spring is not....only 2" is allowed.
Royce, I am after the Calmini lift due to the flex they offer and also to keep the body away from the ground.
Body lift Is to accomodate the 31" tires I plan on getting. I know the 3" lift alone will allow that, I just want to have as much room as possible.
Or is it just the wank factor that appeals to me?
On the weekend I went 4x4ing at glasshouse. On my way down that massive ditch as you first start along the powerlines track. I had to have two mates on my roof to keep the passengers side wheel on the ground (silly I know)
I can't for the life of me grasp suspension :blink: can anyone explain to me, if in this situation...would stiffer springs of helped the wheel stay on the ground (reduced body roll?) or would it of hindered me more.
Post Posted: Tue Aug 02, 2011 6:41 am
i'd say that was a lack of wheel travel, but without knowing the location it's hard to judge.
mine is 5" taller & is about 4" wider & feels pretty stable apart from vertical climbs where the lack of wheel base comes into play.
Post Posted: Tue Aug 02, 2011 6:45 am
So is the max lift on a sierra also 4"? 2 body and 2 suspension?
Every problem can be solved with a Ratchet.
Post Posted: Tue Aug 02, 2011 6:52 am
By law yes. In QLd you are only allowed a 2" spring lift and a 2" body lift that is engineered.
Post Posted: Tue Aug 02, 2011 6:55 am
So calmini lift will fix my wheel travel problem :lol: Do you have any links of pictures with the calmini kit at full flex?
Cheers for your input!
Post Posted: Tue Aug 02, 2011 7:01 am
plenty of pics in my build thread. 8O :wink:
Post Posted: Tue Aug 02, 2011 7:10 am
The calmini kit won't add wheeltravel if you continue to run no bar, winch and stock offset rims. It is possible to use ome (or other) springs to get it to flex without adding weight. The useable parts of the calmini kit are the arms and the diff drop brackets. The rest is either of poor quality (struts, shocks) or designed for massive weight and rim offset. I've driven a Lwb vit on 31's with a calmini kit running ome struts and it rode and handled well, but it was a heavy vit- arb bar, winch, etc.
Post Posted: Tue Aug 02, 2011 7:23 am
I currently have wide offset rims. I wish I could find a bar but not many pop up!
What do you think my best option is? I have plenty of fat friends to sit in the car?
Post Posted: Tue Aug 02, 2011 7:49 am
I'll have a calmini kit up for sale soon! :wink:
Post Posted: Tue Aug 02, 2011 7:58 am
Dibs!!
I emailed you the oth :lol: er day with dibs on it
Post Posted: Tue Aug 02, 2011 8:29 am
Pift where did you get this info? The un-written 'law' is 2 inches spring lift but that actual law is no greater than a 1/3 more than the stock bump-stop height.
Lil Foot!
Post Posted: Tue Aug 02, 2011 8:34 am
I thought it was 2" lift of any kind. Body or Spring. Its either one or the other?
Post Posted: Tue Aug 02, 2011 8:39 am
We are in QLD mate.Yours may be different.
I was actually directing that comment just to spring lift. QLDer's can get bodylifts approved. Pretty sure that's 2" BL
Lil Foot!
Post Posted: Tue Aug 02, 2011 8:46 am
No worries :helloo:
Vehicle: 4wd
Post Posted: Tue Aug 02, 2011 8:51 am
SierraDan wrote:
I thought it was 2" lift of any kind. Tyres, Body or Spring. Its either one or the other?
I won't say all but alot of engineers are counting tyres size increase as lift. :(
Watch out or you'll get sued.
Post Posted: Tue Aug 02, 2011 8:54 am
But you shouldnt be going any taller than 2" anyway ;)
My bad
Vehicle: 4wd
Post Posted: Tue Aug 02, 2011 8:57 am
2" tyre lift. pft, you gone off 33's?
Post Posted: Tue Aug 02, 2011 8:59 am
Shit no!
Just pointing out how "grey" alot of our zooks are haha.
Post Posted: Tue Aug 02, 2011 9:01 am
Careful talking about lift 'amounts' as we have never had that law in QLD and I am not sure if we really are using NCOP in QLD now
Post Posted: Tue Aug 02, 2011 9:17 am
this is where Dan's thread about width/height/COG gives a bit of an idea of stability in a roundabout kind of way, just need more people to measure their zooks to get a better range of mods.
http://auszookers.com/index.php?name=Fo ... ic&t=24061
Post Posted: Tue Aug 02, 2011 9:24 am
Requirements for SA:
http://www.transport.sa.gov.au/pdfs/per ... Height.PDF
Short of it is, no more than 2" via any or all of:
Wheel/tyre increase(Though this can not be greater than 15mm of original items)
Body lift
Suspension lift.
Anything more than 2" has to go through an engineer.
Post Posted: Tue Aug 02, 2011 9:33 am
then you spend all that money engineering it only to have some mechanically retarded police officer still defect you.
Post Posted: Tue Aug 02, 2011 9:37 am
Yep.
Stupid system. Even waving a letter from the engineer in front of them often fails. Because it is up to the owner to prove to TSA that it complies, not the officer.
Post Posted: Tue Aug 02, 2011 9:47 am
yes sir no sir three bags full sir...
Yay for Calmini 3" System And Massive offset rims & 31's...
Who ever said that a 1.6L with 31's and stock gearing was gutless...
They lied!!!
Stocker
Post Posted: Tue Aug 02, 2011 9:55 am
They lied!!!
Haha the clutch loves it.
I will be getting gears before 31's though. Love crawling speed.
Post Posted: Tue Aug 02, 2011 10:02 am
They lied!!!
:roll:
Users browsing this forum: Google [Bot] and 214 guests
