It is currently Fri Oct 02, 2026 7:15 pm
Post Posted: Thu Aug 04, 2011 10:07 am
just wondering im having troubles fitting a 1510 lock rite to the front centre of a w/t sierra iv been told i need a 4 pin hemisphere like out of a n/t diff is this necessary or can i fit it to the original centre??
Post Posted: Thu Aug 04, 2011 10:14 am
You can, but wont be as strong. and you will need chromo 26 spline axles.
Post Posted: Thu Aug 04, 2011 10:19 am
The 1510 reuses the factory side gears so you dont 'need' cromo axles. You also dont need a 4 pin centre, mine worked fine for the couple years it was in in a 2 pin centre.
Post Posted: Thu Aug 04, 2011 10:27 am
ok thanks guys just as long as it gets setup right. because iv had it been setup about 3 times and it still not working
Post Posted: Thu Aug 04, 2011 10:28 am
what isnt working with the install?
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Thu Aug 04, 2011 10:34 am
When i tryed to install my lockwrong in a WT 2 pin center it interfered with the lip on the outside of the side gears so would not let the locker engage.
We are amphibious
Post Posted: Thu Aug 04, 2011 10:38 am
apparently late model 2 pin diffs, after 94 or so have a lip on the side gears that needs to
be machined off. i have a 1510 in a 2 pin diff and it went together fine. been there for
4 or so years.
Post Posted: Thu Aug 04, 2011 10:41 am
on the front face of the gears?
Post Posted: Thu Aug 04, 2011 10:57 am
my diff is a 92 model
Post Posted: Thu Aug 04, 2011 10:59 am
what problem are you having but?
Post Posted: Thu Aug 04, 2011 11:12 am
the first time it sheared all the little pins and springs the second time im not sure what it did but its just wasnt locking at all.
Post Posted: Thu Aug 04, 2011 11:16 am
sounds like its loose..
Did you put the washers in behind the locker gears?
Post Posted: Thu Aug 04, 2011 11:21 am
i think they did i didnt do it myself. so it should lock even in a 2 pin centre.?? or should i track down a 4 pin centre
Post Posted: Thu Aug 04, 2011 11:23 am
Mate I should have a few 4 pin Sierra carriers laying around. I will have a look tomorrow if you want. You still got my phone number?
Clearance Hole Technology :P
Post Posted: Thu Aug 04, 2011 11:36 am
ohh hey arron yea thanks for that mate a would be great if you do
Post Posted: Thu Aug 04, 2011 11:50 am
Call me tomorrow arvo if you want, I'll check before then if I have one. If not I'll try to find your number.
Post Posted: Thu Aug 04, 2011 1:17 pm
Yeah the internals of it resemble a vitara diff but smaller.
The lip sits out the same level as the teeth on the gear.
its a 89 sj70.
We are amphibious
Users browsing this forum: Google [Bot] and 157 guests
