It is currently Wed Oct 07, 2026 5:27 pm
Post Posted: Thu Aug 04, 2011 12:12 am
i am currently running the standard Z172 filter on my 91 sierra but am going to install an oil filter sandwich plate so i can run some gauges
my question is since the plate is a little under 1in thick i'm going to need to run a smaller filter as it will more than likely hit the engine mount
i've read a Z418 filter has the same thread and is smaller but are there any complications with running a smaller filter?
Post Posted: Thu Aug 04, 2011 12:13 am
i run z418 on mine no worries at all and have been for about 8 years now.
Post Posted: Thu Aug 04, 2011 12:16 am
cool good news do you run a sandwich plate or is there another reason you run the smaller filter?
Post Posted: Thu Aug 04, 2011 12:20 am
I run the 418 on my vit, its the standard fitment on a baleno, and so much easier to get a hold of.
Post Posted: Thu Aug 04, 2011 12:22 am
i was running the 1.3 which had no need for it really, was just easier to get at the time i think... now running 1.6 its standard fitment on that so yeah.
ah good to know thanks well it looks like im changing to the 418 from now on then
Vehicle: 92 Suzuki Sierra
Post Posted: Thu Aug 04, 2011 12:24 am
i think from memory the z418 is used in newer model suzuki's for clearance reason (if not i know there is a squatter shaped filter that is listed as compatible for late model suzuki's ) If you change your oil regularly it shouldn't be an issue
Have you checked to see if the z172 actually hits? Just unscrew your existing one and test fit. a v8 Z9 filter fits and its freakin huge.
-Santos
Post Posted: Thu Aug 04, 2011 12:27 am
Santos wrote:
i think from memory the z418 is used in newer model suzuki's for clearance reason (if not i know there is a squatter shaped filter that is listed as compatible for late model suzuki's ) If you change your oil regularly it shouldn't be an issue.
The 418 is standard fitment on v6 prados, so id think it has the capacity required
Post Posted: Thu Aug 04, 2011 12:33 am
yeah i am just waiting for my sandwich plate to turn up then i can trial fit but if the 418 is used without an issue i'll just run the smaller filter
Vehicle: Sj70 tintop
Post Posted: Thu Aug 04, 2011 12:55 am
ryco z125 fits, and is pretty small.
howd you go with your fuel drama?
Sj70 tintop
Post Posted: Thu Aug 04, 2011 1:01 am
yeah seems to have sorted itself out but i honestly think it picked up some shit from the fuel tank and was a small blockage
ran it last night for a while without a drama
Post Posted: Thu Aug 04, 2011 1:37 am
Most late model Toyota's with a screw on filter run the 418, Hilux, Hiace, Camry, etc
Post Posted: Thu Aug 04, 2011 2:07 am
and mini's :wink:
Post Posted: Thu Aug 04, 2011 3:57 am
and yamaha 1600efi outboards
Post Posted: Thu Aug 04, 2011 3:59 am
geez no wonder the 418 is easier to source
Post Posted: Thu Aug 04, 2011 4:17 am
Hmmmmm, any reason you need a sandwich plate to run gauges?
You can but t-adapters that screw into the oil pressure switch port on the block.
Post Posted: Thu Aug 04, 2011 4:28 am
can you? sorry im all new to gauges etc
what i have is an electronic oil temp gauge with sender so im trying to figure out the best way to fit the sender - so far i can only find these sandwich plates?
Post Posted: Thu Aug 04, 2011 4:44 am
are all threads for the t-piece 1/8th NPT?
Post Posted: Thu Aug 04, 2011 5:09 am
VDO do them too I think, but a quick search found this.
GT
http://www.namiiss.com.au/catalogue/vdo ... esadapters
Post Posted: Thu Aug 04, 2011 5:25 am
cheers mate that looks like a better option
Post Posted: Thu Aug 04, 2011 6:42 am
there's also two oil gallery ports side by side on the G-series block that you can screw oil gauges into and still run the factory pressure switch
Post Posted: Thu Aug 04, 2011 8:37 am
So does anyone know the number of the filter for a 2.4 GV (2009)
Post Posted: Thu Aug 04, 2011 9:12 am
Have you bothered to search the RYCO website. Its listed in their online catalog. Z734
Post Posted: Thu Aug 04, 2011 9:31 am
But asking on forums is so 2011. Researching for yourself was so last year... hell even last decade.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Aug 04, 2011 10:49 am
oh are you talking about the one right beside it with like and allen key plug?
Post Posted: Fri Aug 05, 2011 9:59 pm
Yep
Post Posted: Sun Aug 07, 2011 11:17 pm
hmmm might not be able to use that on the allen key plug won't budge
Users browsing this forum: No registered users and 166 guests
