It is currently Wed Nov 18, 2026 4:35 am
Post Posted: Wed Aug 18, 2010 10:13 am
hi everyone, i was just wondering what was the biggest alternator you can fit on a 1992 1.6L vitara? As in amps, mounting etc.
Thanks
Post Posted: Wed Aug 18, 2010 10:30 am
falcon alternator! search
Post Posted: Wed Aug 18, 2010 10:33 am
Easy 8)
You aren't really limited by amps.
Tell us what you are running that draws on your electrical system, and it may give some of the sparky members here a better idea of what size you should shoot for.
Peter
Post Posted: Wed Aug 18, 2010 10:35 am
Grimbo.... is that you? 8O :lol: :lol:
Post Posted: Wed Aug 18, 2010 10:38 am
That's what I was thinking, bit rude...... :roll:
Post Posted: Wed Aug 18, 2010 10:39 am
i should upgrade mine sometime my head lights have a small dimming problem
Post Posted: Wed Aug 18, 2010 10:43 am
It's a pretty common conversion on the Sierra's but I've never read/heard anyone doing it to a Vitara.
Post Posted: Wed Aug 18, 2010 10:45 am
All the bits that make it less than bolt on on a sierra are already fitted to a vit, its easier to fit than it is to type bigger and alternator into teh search box :)
Post Posted: Wed Aug 18, 2010 10:47 am
ohhh that sounds promising.... what about the SV420's J20a?
Post Posted: Wed Aug 18, 2010 10:48 am
arent they like coilys?
should fit I would think, but who knows try it :)
Post Posted: Wed Aug 18, 2010 10:50 am
:lol: :lol:
Post Posted: Wed Aug 18, 2010 10:52 am
this sounds like another job for Captain TSOR to prototype on the test mule
Post Posted: Wed Aug 18, 2010 10:58 am
then he can make one for me and ill test the h20a version
mine doesnt like the sub and i only have one in at the moment people think im flashing them sometimes
Post Posted: Wed Aug 18, 2010 11:05 am
You need a better battery. Or a capacitor. The alt will never keep up with the draw of a sub.
Post Posted: Wed Aug 18, 2010 11:07 am
yeah i should get a capcitor and dual batteries and really should upgrade the alt cabling that helps alot usally but its all work and u know im a lazy prick
Post Posted: Wed Aug 18, 2010 11:41 am
Timbo up here did the swap on his Vit!
:D :D
suprised more Vit owners havent done it
Post Posted: Wed Aug 18, 2010 11:47 am
:D :D
cool, but tell me how to search for something that hasn't been posted before? :wink:
maybe we need Timbo to do a write up?
Post Posted: Wed Aug 18, 2010 11:57 am
On a 1.6 vit its literally remove old alt, put new on in with a longer belt and change the plug to suit
Post Posted: Wed Aug 18, 2010 12:04 pm
:D :D
Yeah had a brain snap thought it was a common swap for sierras and vits :oops:
As royce said though pretty sure Timbo just swapped the units over and did some customising on the top bracket and bobs your uncle
Post Posted: Wed Aug 18, 2010 8:47 pm
Check my build thread... I had an EF Falcon 110A alt on my 1.3 and then swapped it to the G16B when I upgraded.
Post Posted: Wed Aug 18, 2010 9:45 pm
2 x headlights
2 x tail lights
2 x brake lights
2 x indicators (at a time)
1 x reversing light
1 x windscreen wiper motor
1 x tiny starter motor
and a little bit for the coil
get a 2 stroke they don't need much...
(and may not have the power to spin a falcon alternator...)
Post Posted: Wed Aug 18, 2010 10:14 pm
2stroker wrote:
2 x headlights
2 x tail lights
2 x brake lights
1 x reversing light
So a eng that run's on oil won't need to see in front of em, because thay can't see behind em?? :?
thay still need all of your list!! :wink:
Post Posted: Wed Aug 18, 2010 10:34 pm
2stroker wrote:
2 x headlights
2 x tail lights
2 x brake lights
1 x reversing light
You start your car, in reverse, with an indicator on, headlights on and foot on the brake with the wipers running?
Geez ive heard of funny things you need to do do start some old cars but that takes the cake :)
That must take some prior planning, do you have a pre flight checklist you go through?
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Tue Aug 02, 2011 11:10 am
Ok...
I used the search button and found this, so threadmine time :)
I thought this would be preferable to a new thread.
I am looking at doing this (92 SWB 1.6 Vit) and from what I can see, I need the alternator and a new belt and thats all.
What belt do I need?
Thanks!
Pete
Vehicle: Zookless
Post Posted: Tue Aug 02, 2011 11:18 am
Here's a Falcon alternator on a G16B.
I'm pretty sure I just used the original belt...
Post Posted: Wed Aug 03, 2011 4:18 am
I have done the falcon alt swap on a 92 vit. You will need to grind some of the housing away on the top of the new alt to get enough adjustment. You will see this when you try to mount it up. Get the falcon plug with the alt so you can swap the wires over.
I took the charge wire strait to the battery and did away with genuine wire which dissapears into the loom. You will also need to drill out the bottom mount holes because the falcon bolt is bigger. It is an easy swap over and there is a good post on here somw where for it. I also put in a large fusable link in the lead to the battery, I don't know how nesesary this is, but i like having fuses in things especially when big currnet is involved.
The alternator you need is a mitsi brand ( they have a ford sticker on them) 110 amps I think the part no. is ad110. I have also come across a 100 amp model in a Falcon that looks to be identical.
I hope all this helps.
Post Posted: Wed Aug 03, 2011 4:23 am
Thanks heaps! Did you use the factory belt?
Post Posted: Thu Aug 04, 2011 9:37 pm
I am running a 4pk 825. I think the original is a 810? standard both belts are the same.
Vehicle: Sj70 tintop
Post Posted: Thu Aug 04, 2011 9:43 pm
dont gv have a 110amp alt?
Sj70 tintop
Post Posted: Fri Aug 05, 2011 10:49 am
Grab the Wiring Harness and Fuse Box out of the Falcooon too :) I mounted it up above the brake master and it supports a 100A fuse. i'll post a couple of pics up 2morro :)
Stocker
Users browsing this forum: No registered users and 40 guests
