| jimny diff ratios??? http://auszookers.com/forum/viewtopic.php?f=5&t=24633 |
| Author: | DavidSoden [ Mon Aug 08, 2011 1:29 am ] |
| Post subject: | jimny diff ratios??? |
someone please help, i fucked my rear diff in my jimny on the weekend, and i am now hunting a new one from the wreckers, but i dont know what engine or ratio my car is/has. its a 2002 model. 1.3. thats all i know really. help would be much apreciated! thanks |
| Author: | tanshi [ Mon Aug 08, 2011 1:39 am ] |
| Post subject: | Re: jimny diff ratios??? |
i think they are either 4.1 or 4.3 i believe. think it makes a difference if they are manual or auto aswell 2002 i think will be the m13 motor |
| Author: | DavidSoden [ Mon Aug 08, 2011 1:56 am ] |
mines a manual, does that help? ha |
| Author: | tanshi [ Mon Aug 08, 2011 1:59 am ] |
i think yours will be 4.1 check your compliance plate to see what motor it is, it will either be g13bb or m13 then tell the wreckers that your after a diff for a jimny with a *insert engine type here* and manual gearbox |
| Author: | DavidSoden [ Mon Aug 08, 2011 2:05 am ] |
mine is an m13a engine, so you reckon the ration will be 4.1? |
| Author: | tanshi [ Mon Aug 08, 2011 2:06 am ] |
from what i know about Jimnys yes. pull the diff out and count the teeth is the best way to be sure |
| Author: | DavidSoden [ Mon Aug 08, 2011 2:10 am ] |
thanks heaps man |
| Author: | tanshi [ Mon Aug 08, 2011 2:12 am ] |
should still be able to count the stubs |
| Author: | DavidSoden [ Mon Aug 08, 2011 2:13 am ] |
true haha. well thanks heaps anyway man |
| Author: | ZookiMonsta [ Mon Aug 08, 2011 2:41 am ] |
Yep, will be a 4.09. Not many Jimnys had this ratio so good luck finding one, most were 4.3. |
| Author: | mnemonix [ Mon Aug 08, 2011 2:59 am ] |
I'm yet to see a jimny that wasn't 4.09. The Suzuki literature says only Auto's were 4.09 however this doesn't seem to be true. |
| Author: | ZookiMonsta [ Mon Aug 08, 2011 3:09 am ] |
mnemonix wrote: I'm yet to see a jimny that wasn't 4.09. The Suzuki literature says only Auto's were 4.09 however this doesn't seem to be true.
I have dismantled many Jimny diffs and most were 4.3, I hunted for 6weeks trying to find a 4.09. |
| Author: | DavidSoden [ Mon Aug 08, 2011 3:18 am ] |
a guy has found me 2, im just waiting for him to call me back with the ratio |
| Author: | alien [ Mon Aug 08, 2011 6:13 am ] |
putting 4.3s in (assuming you can) would be good to correct gearing for a 215/75r15 tyre though! |
| Author: | zukenutter [ Mon Aug 08, 2011 6:47 am ] |
4.09 was up to the 2006, 2006 on VVT models are 4.3, I've heard autos are different but yet to confirm that. |
| Author: | Bugsta [ Mon Aug 08, 2011 8:09 am ] |
I have 2 4.09 diffs I have tried to sell. Do you still need one David? edit: Sorry, its front ones I have. |
| Author: | DavidSoden [ Mon Aug 08, 2011 10:53 am ] |
I may need one for the front actualy! I'm not positive yet though. You will Be the first though if I find out I need one |
| Author: | DavidSoden [ Mon Aug 08, 2011 11:06 am ] |
Zookimonsta, you positive that it will be a 4.09? |
| Author: | Bugsta [ Mon Aug 08, 2011 11:25 am ] |
DavidSoden wrote: Zookimonsta, you positive that it will be a 4.09?
Mine is a 08 manual and is 4.3. As far as I understand, the earlier manuals were 4.1(4.09 to be accurate). If you have the diff centre apart you can easily find out by counting the teeth. The 4.3:1 is 43 on the crown(ring) gear to 10 on the pinion, and the 4.09 is 45 to 11. The autos I can't be sure. You can also find out when its all together by doing a rotation test and calculation. I posted a thread on how I did this many months ago. |
| Author: | Bugsta [ Mon Aug 08, 2011 11:31 am ] |
ZookiMonsta wrote: mnemonix wrote: I'm yet to see a jimny that wasn't 4.09. The Suzuki literature says only Auto's were 4.09 however this doesn't seem to be true. I have dismantled many Jimny diffs and most were 4.3, I hunted for 6weeks trying to find a 4.09. When I was in need of a rear diff, all I could find was 4.1's I ended up getting a crown and pinion from darkhorse (I think) in Sydney posted to me from his Vit. |
| Author: | DavidSoden [ Tue Aug 09, 2011 12:14 am ] |
Thanks heaps guys, I'm picking up a 4.1 later on today, hope it's the right one haha |
