It is currently Fri Oct 09, 2026 3:42 pm
Vehicle: Jimny
Post Posted: Mon Aug 08, 2011 11:37 pm
Hey guys I was justwandering how a set of 15-8 inch rims would go on a Jimny I plan to run 31-10.5
DONT BUY A GQ! zooks are better. i have both :)
Post Posted: Mon Aug 08, 2011 11:44 pm
You'll need to do some heavy guard trimming and cover the protruding tyre with a flare extension, but its well worth the effort IMO.
Start hacking! :lol:
EDIT: you'll get away with 7" rims for 31's. :wink:
Post Posted: Mon Aug 08, 2011 11:45 pm
you're gonna need do do a guard chop to fit the 31's so it won't be an issue.
I went 15x7 -38 offset on mine though - theory being the skinnier rim will hold the tyre on better, and i still have the width of a reasonable offset 15x8.
Vehicle: Jimny
Post Posted: Tue Aug 09, 2011 1:40 am
Ah I see. The reason i asked about the 8 inch rims isbecause I'm bidding on a set. On eBay. Vitara Jimny pcd the same?
Post Posted: Tue Aug 09, 2011 1:42 am
Yes the PCD is the same. But the offsets are not. What are the specs on the rims?
Vehicle: Jimny
Post Posted: Tue Aug 09, 2011 2:06 am
15-8 -22 offset
Post Posted: Tue Aug 09, 2011 2:43 am
Thats a good offset, but it will give you a pretty wide scrub raius. So you will have to trim around the base of the firewall, the top of the wheel arch, and the bumper.
Vehicle: Jimny
Post Posted: Tue Aug 09, 2011 6:25 am
Yeah it doesn't bother me using the old angle grinder :-)
Post Posted: Tue Aug 09, 2011 7:11 am
i just did the 31's on a jimny, but i used a 15x7 -12 rim. i was going to go for a 15x8 -28 rims off a mate but i was worried about radius scrub. the 15x7 worked out perfect ( yet to go out wheeling but should be sweet) and only cost me $59 a rim from bob jane.
Vehicle: Jimny
Post Posted: Tue Aug 09, 2011 7:39 am
I seen your right up Andrew. And ur car looks fucking mean! I hope I can get mine to look simialar
Users browsing this forum: No registered users and 170 guests
