| Jimny 8 inch rims http://auszookers.com/forum/viewtopic.php?f=5&t=24661 |
| Author: | zammit [ Mon Aug 08, 2011 11:37 pm ] |
| Post subject: | Jimny 8 inch rims |
Hey guys I was justwandering how a set of 15-8 inch rims would go on a Jimny I plan to run 31-10.5 |
| Author: | Fatzook [ Mon Aug 08, 2011 11:44 pm ] |
| Post subject: | Re: Jimny 8 inch rims |
You'll need to do some heavy guard trimming and cover the protruding tyre with a flare extension, but its well worth the effort IMO. Start hacking! EDIT: you'll get away with 7" rims for 31's. |
| Author: | alien [ Mon Aug 08, 2011 11:45 pm ] |
you're gonna need do do a guard chop to fit the 31's so it won't be an issue. I went 15x7 -38 offset on mine though - theory being the skinnier rim will hold the tyre on better, and i still have the width of a reasonable offset 15x8. |
| Author: | zammit [ Tue Aug 09, 2011 1:40 am ] |
Ah I see. The reason i asked about the 8 inch rims isbecause I'm bidding on a set. On eBay. Vitara Jimny pcd the same? |
| Author: | Fatzook [ Tue Aug 09, 2011 1:42 am ] |
zammit wrote: Ah I see. The reason i asked about the 8 inch rims isbecause I'm bidding on a set. On eBay. Vitara Jimny pcd the same?
Yes the PCD is the same. But the offsets are not. What are the specs on the rims? |
| Author: | zammit [ Tue Aug 09, 2011 2:06 am ] |
15-8 -22 offset |
| Author: | Fatzook [ Tue Aug 09, 2011 2:43 am ] |
Thats a good offset, but it will give you a pretty wide scrub raius. So you will have to trim around the base of the firewall, the top of the wheel arch, and the bumper. |
| Author: | zammit [ Tue Aug 09, 2011 6:25 am ] |
Yeah it doesn't bother me using the old angle grinder |
| Author: | andrew88 [ Tue Aug 09, 2011 7:11 am ] |
i just did the 31's on a jimny, but i used a 15x7 -12 rim. i was going to go for a 15x8 -28 rims off a mate but i was worried about radius scrub. the 15x7 worked out perfect ( yet to go out wheeling but should be sweet) and only cost me $59 a rim from bob jane. |
| Author: | zammit [ Tue Aug 09, 2011 7:39 am ] |
I seen your right up Andrew. And ur car looks fucking mean! I hope I can get mine to look simialar |
