It is currently Fri Oct 09, 2026 10:12 am
Post Posted: Mon Aug 08, 2011 1:29 am
someone please help, i fucked my rear diff in my jimny on the weekend, and i am now hunting a new one from the wreckers, but i dont know what engine or ratio my car is/has. its a 2002 model. 1.3. thats all i know really. help would be much apreciated! thanks :)
02 Jimny, 235's, 3.5" springs
Post Posted: Mon Aug 08, 2011 1:39 am
i think they are either 4.1 or 4.3 i believe.
think it makes a difference if they are manual or auto aswell
2002 i think will be the m13 motor
Post Posted: Mon Aug 08, 2011 1:56 am
mines a manual, does that help? ha
Post Posted: Mon Aug 08, 2011 1:59 am
i think yours will be 4.1
check your compliance plate to see what motor it is,
it will either be g13bb or m13
then tell the wreckers that your after a diff for a jimny with a *insert engine type here* and manual gearbox
Post Posted: Mon Aug 08, 2011 2:05 am
mine is an m13a engine, so you reckon the ration will be 4.1?
Post Posted: Mon Aug 08, 2011 2:06 am
from what i know about Jimnys yes.
pull the diff out and count the teeth is the best way to be sure
Post Posted: Mon Aug 08, 2011 2:10 am
thanks heaps man :) haha that will be hard, i opened the diff yesterday to drain a bit of the oil, and chunks of metal (stripped teeth) came out with it
Post Posted: Mon Aug 08, 2011 2:12 am
should still be able to count the stubs :D
Post Posted: Mon Aug 08, 2011 2:13 am
true haha. well thanks heaps anyway man :) !
Post Posted: Mon Aug 08, 2011 2:41 am
Yep, will be a 4.09. Not many Jimnys had this ratio so good luck finding one, most were 4.3.
Vehicle: '96 LWB trayback
Post Posted: Mon Aug 08, 2011 2:59 am
I'm yet to see a jimny that wasn't 4.09. The Suzuki literature says only Auto's were 4.09 however this doesn't seem to be true.
Post Posted: Mon Aug 08, 2011 3:09 am
I have dismantled many Jimny diffs and most were 4.3, I hunted for 6weeks trying to find a 4.09.
Post Posted: Mon Aug 08, 2011 3:18 am
a guy has found me 2, im just waiting for him to call me back with the ratio
Post Posted: Mon Aug 08, 2011 6:13 am
putting 4.3s in (assuming you can) would be good to correct gearing for a 215/75r15 tyre though!
Post Posted: Mon Aug 08, 2011 6:47 am
4.09 was up to the 2006, 2006 on VVT models are 4.3, I've heard autos are different but yet to confirm that.
Post Posted: Mon Aug 08, 2011 8:09 am
I have 2 4.09 diffs I have tried to sell.
Do you still need one David?
edit: Sorry, its front ones I have.
Post Posted: Mon Aug 08, 2011 10:53 am
I may need one for the front actualy! I'm not positive yet though. You will
Be the first though if I find out I need one :)
Post Posted: Mon Aug 08, 2011 11:06 am
Zookimonsta, you positive that it will be a 4.09?
Post Posted: Mon Aug 08, 2011 11:25 am
Mine is a 08 manual and is 4.3.
As far as I understand, the earlier manuals were 4.1(4.09 to be accurate). If you have the diff centre apart you can easily find out by counting the teeth. The 4.3:1 is 43 on the crown(ring) gear to 10 on the pinion, and the 4.09 is 45 to 11.
The autos I can't be sure.
You can also find out when its all together by doing a rotation test and calculation. I posted a thread on how I did this many months ago.
Post Posted: Mon Aug 08, 2011 11:31 am
When I was in need of a rear diff, all I could find was 4.1's I ended up getting a crown and pinion from darkhorse (I think) in Sydney posted to me from his Vit.
Post Posted: Tue Aug 09, 2011 12:14 am
Thanks heaps guys, I'm picking up a 4.1 later on today, hope it's the right one haha
Users browsing this forum: Google [Bot] and 221 guests
