http://auszookers.com/forum/
rear brake drums stuck
http://auszookers.com/forum/viewtopic.php?f=5&t=24687
Author:  flyboytroy [ Tue Aug 09, 2011 9:18 am ]
Post subject:  rear brake drums stuck
anyone got any ideas.my rear brake drums wont come off. i have disconnected handbrake cable and still stuck? :(
Author:  Kermy87 [ Tue Aug 09, 2011 9:44 am ]
Post subject:  Re: rear brake drums stuck
Use a big fu&@ off hammer, worked for me,
Nahh I'd bolt Ur wheel to the drum make sure The 4 nuts holding the drum on are undone and giv it an almighty wiggle , shuv, prod, push and a kick , might work ?? :blink: ?? Worth a try
Author:  bohuler [ Tue Aug 09, 2011 9:48 am ]
There is a a brake adjustment on the back of the drum. Its basically a thread that adjusts the brake. You need to stick a small flat bladed screw driver into the hole feel around a bit. If you can wait till tomorrow i will get some pics up tomorrow morning showing what i mean. Kinda hard to explain, easier to show with pics :D Maybe someone else might be able to articulate it better then me but meh, whatever :D
Dave
Author:  bohuler [ Tue Aug 09, 2011 10:14 am ]
Or a slide hammer. Attach it to one of the studs with a wheel nut and belt the shit out of it :D :D :D (it may bend something, i have bent the brake pad metal bit doing this once, just a word of warning!!)
Author:  SierraDan [ Tue Aug 09, 2011 10:25 am ]
if the four nuts in the middle are definitely off. and the brakes are not on.
Hit a hammer with some decent blows around the circumfrence of the drum it should wiggle off.
Author:  PJ.zook [ Tue Aug 09, 2011 11:21 am ]
Either a hammer as others have suggested, or keep dumping the clutch in first and reverse until it releases heh.
Author:  pyrohamish [ Tue Aug 09, 2011 11:40 am ]
wind the wheel nuts out so there is only a few threads left and use the wheel as a slide hammer
Author:  joe5701 [ Tue Aug 09, 2011 11:43 am ]
dont think he wants to take the axle out aswell
Author:  SierraDan [ Tue Aug 09, 2011 11:46 am ]
different nuts. undo the four axle nuts and leave the wheel nuts on a bit.
Author:  flyboytroy [ Wed Aug 10, 2011 6:48 am ]
big hammer did the trick.thanx guys :D
