Posted: Fri Aug 05, 2011 6:59 am
have you got front & rear LWB vit springs, you might not get much out of the front but the rear should give you 40mm'ish i guess. then chucking the 15mm spacer & strut spacer in the front to try & balance it out could work well.
it's always going to be a bit of a guessing game, i've never messed around with spacers & other springs but there is heaps of info out there.
the rear you really should flex it with no shocks & measure to get the correct lengths.
Joined: Thu Oct 07, 2010 8:02 am Posts: 179 Location: 2450
Posted: Fri Aug 05, 2011 7:29 am
Yeah, have the full set of LWB springs. Hopefully they give a little lift in the front. Would be a bit of a pain to have the ass-end of the car high up and the front only at stock
if you get 40 out of the rear and none out of the front just with the springs you could swap the spacers around and use the 15s in the rear and run the 30s in the front just a little cut on the front to level it out.
my lwb runs pretty similar setup i just have king spring in the rear and run flipped mounts. it sits a little higher in the front but i was to lazy to cut spring to level it out. i had it the other way and found the big spacers stopped a fair bit of flex in the rear.
_________________ lseries 2" body lift king springs 27" boots and a
Users browsing this forum: No registered users and 475 guests
