| grinding the block to fit starter motor ????? http://auszookers.com/forum/viewtopic.php?f=5&t=24842 |
| Author: | shane1992 [ Mon Aug 15, 2011 10:40 am ] |
| Post subject: | grinding the block to fit starter motor ????? |
Heyy, does anyone know how much is needed to grind off the block of a G16B to fit a 1.3 starter? Cause I have a 1.6 starter too but its identicle tp the 1.3... im doing a 1.6 conversion on my sierra |
| Author: | jimny_timmy [ Mon Aug 15, 2011 10:41 am ] |
| Post subject: | Re: grinding the block to fit starter motor ????? |
Dude no need to post 3 threads for the one topic... |
| Author: | alien [ Mon Aug 15, 2011 10:46 am ] |
other way around - you grind the starter to fit the block. alien wrote: How to grind a 1.3 starter to fit 1.6:
Step 1: Grind ![]() Step 2: Grind some more ![]() Step 3: Better grind it one more time ![]() Step 4: Admire grinding skills ![]() Step 5: Smooth it out a bit ![]() Step 6: Rust protection ![]() To fit: Disconnect battery, Remove airbox, remove original starter, put new starter in, re-fit airbox, re-connect battery... |
| Author: | SSSIERA [ Mon Aug 15, 2011 11:07 am ] |
i spoke to the guy at the suzi store about it when i was gona buy a zook with a 1.6 in it and aparently its not recomended to do this. coz although they look the same. they over ingage or something and thats why people burn threw them all the time the guys name was brian and he was more than happy to help me over the phone. as u can probably tell idk much about them but it might be worth looking at btw suzistore build a special starter motor for that conversion its like 300 bucks with a waranty! |
| Author: | birko [ Mon Aug 15, 2011 1:01 pm ] |
baha, i think above pics are suzi store. But yep you gotta grind a fair bit off. Who cares if its not recommened, if youve got a 1.3 starter already, grind it and fit it. You can replace it IF it stuffs up |
| Author: | alien [ Mon Aug 15, 2011 1:51 pm ] |
or buy the reduction starter =) |
| Author: | BlueSuzy [ Mon Aug 15, 2011 2:39 pm ] |
Or get i turned down on a lathe, then smooth off the alloy housing section |
| Author: | shane1992 [ Mon Aug 15, 2011 9:55 pm ] |
jimny_timmy wrote: Dude no need to post 3 threads for the one topic...
do you actually think I meant to post 3 on purpose? I'm sick of idiots like you on this forum that have to pick out little shit to winge about! Thanks for the little thread on how to do it... Ill give it a go an see how it turns out |
| Author: | squibby [ Tue Aug 16, 2011 5:41 am ] |
Grinder is my new favourite tool. I didn't know that my $30 grinder with 3x $2.64 100mm cutting disks would cut through about 1m of high tensile 5mm steel until last weekend. Now I know I can change metal I'm on a high! just have to figure out how to weld next... GRINDERs ROCK! |
| Author: | BlueSuzy [ Tue Aug 16, 2011 7:42 am ] |
metal nOoB^ |
