| suzuki g16b engine help http://auszookers.com/forum/viewtopic.php?f=5&t=24850 |
| Author: | orangeshannon [ Mon Aug 15, 2011 8:42 pm ] |
| Post subject: | suzuki g16b engine help |
hi i got a 1994 suzuki vitara g16b engine but it currently has the g16a head (carby) i have at home another g16b engine and head but its from 1991 will the 91 g16b head fit on the 94 g16b block and how do i go about for gaskets are they both the same or do i need one or the other? can you please help me |
| Author: | want33s [ Mon Aug 15, 2011 9:56 pm ] |
| Post subject: | Re: suzuki g16b engine help |
Any G16B head will fit on any G16B block as long as it still has the 16V pistons fitted. |
| Author: | orangeshannon [ Mon Aug 15, 2011 11:20 pm ] |
so i could just buy the valve regrind kit for the 91 head and that gasket will line up to all the jets ect...? |
| Author: | zooky08 [ Mon Aug 15, 2011 11:44 pm ] |
Jas is saying any g16b head will fit as long as the block still has the 16valve piston. G16a is 8 valve so the engine might have 8 valve piston. G16b pistons have 4 Valve reliefs per piston G16a only has two. Just buy a g16b head gasket |
| Author: | orangeshannon [ Tue Aug 16, 2011 1:36 am ] |
thanks thats all i need to know i just have to take the G16a head thats on there to see if they have changed the pistons im hoping not |
| Author: | 11_evl [ Tue Aug 16, 2011 3:09 am ] |
The pistons on a carby head should be different to the pistons with EFI head. Head gaskets are all the same. |
| Author: | orangeshannon [ Tue Aug 16, 2011 4:25 am ] |
the only thing that i dont know yet is if i have the carby pistons in my fuel injected block to run with the carby head im thinking now that it has carby pistons |
| Author: | Ben_Sierra [ Tue Aug 16, 2011 4:32 am ] |
11_evl wrote: The pistons on a carby head should be different to the pistons with EFI head. Head gaskets are all the same.
To be completely clear, since there are a few strange combinations out there: Pistons in a 16 valve engine are different from pistons in an 8 valve engine. Its to do with valves, not how the fuel is delivered. |
