It is currently Mon Jun 22, 2026 2:44 pm
Vehicle: White A/T Jimny
Post Posted: Sat Aug 27, 2011 7:44 am
Hey so i recently changed over my stock suspension to an OME 40mm setup and noticed that when i hit about 60kph the steering wobbles quite badly. Hoping its something simple like allignment, camber, balance etc. any ideas?
Thanks
Oh and running the standard 205/70R15 tyres and rims
Vehicle: Jimny, Lifted on 30's
Post Posted: Sat Aug 27, 2011 7:50 am
Theres alot of different factors to take into account. Most people i have talked to and have fixed this problem all fixed it by doing different things. Myne was fixed by getting new tyres and a wheel alignment and Balance. There are alot of threads on this site about this problem. Go to the search function and type jimny death wobble, steering wobble etc and you will find alot of information about it! :D Hope that helps!
http://www.auszookers.com/index.php?nam ... mny+wobble
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Sat Aug 27, 2011 7:54 am
yeh been having a look. just a bit lost seeing as im not runnin any bigger tyres and it started as soon as i put the suspension in. Id imagine that raising the car would alter the allignment?
Post Posted: Sat Aug 27, 2011 8:04 am
I had to get the 3 degree caster.
When I had the suspension installed the car shook like mad as soon as I hit about 60.
I got the 3 degree caster installed and it fixed it.
Better than stock...but not by much.
 Profile YIM
Post Posted: Sat Aug 27, 2011 8:05 am
Yeah after putting in your suspension you realy do need to do a wheel allignment.. See how it goes after that :D
Post Posted: Sat Aug 27, 2011 8:06 am
oh geese not this age old bloody mystery again. just hit the search bar and you'll find a fair few posts about it with all soughts of solutions.
just remember a steering dampner is no cure :)
Stocker
Post Posted: Sat Aug 27, 2011 8:22 am
The only alignment spec you have changed is the caster. It's now out of spec.
Correct the caster.
PS ever had a shopping trolley with a wheel that flutters uncontrollably? That's what happens when the caster comes out of spec.
Vehicle: 2004 KJ jeep cherokee
Post Posted: Sat Aug 27, 2011 9:27 am
was the alignment done corectley? did they put the wrong caster bolts in? might wanna look into it
40mm lift shoundn't affect the caster what so ever, but I could be wrong as mubby said, could be a few items. I only know this from my jimny 40mm ome lift
If at first you don't suceed... lower your standar
Post Posted: Sat Aug 27, 2011 9:32 am
:crazy:
Now raise the chassis attachment point (where the big blue arrow tip is) 40mm - now just exactly what will happen to the caster?
More lift=less caster=death wobbles.
PS yes, the picture is from a late 1970's ford, but the principle is the same with the jimny.
Post Posted: Sat Aug 27, 2011 12:30 pm
yeh definitely seems to be the castor. Does this mean i will need 2 get the castor correction bushes or is this something a simple alignment and balance can solve?
Post Posted: Sat Aug 27, 2011 1:26 pm
Yes definaty get caster correction bushes installed and set correctly for the 40mm lift.
Vehicle: LJ20 LJ50
Post Posted: Tue Sep 13, 2011 5:44 am
http://item.rakuten.co.jp/apio/1020-01/
here is a new item that you can get to help with steering wobble
[For Jimny JB23]
kingpin system preload (left set)
Adjustable kingpin
Item Number 1020-01
Price 16,000 yen (16,800 yen including tax) including postage
Qty
E-mail to a friend
Add to favorite products
Write a Review
For Jimny JB23 (left set)
is a system that can be adjusted appropriately and subtly than the torque wrench in the anti-genuine Suzuki parts and shim type of measures the steering judder and shimmy handle specific axle rigid vehicles. (2010-193 wish utility model) [Specifications] Preload Pin: HRC38 ~ 43 + Vacuum hardening chrome-molybdenum steel SCM435 kingpin base: S35C lock nut: S35C plating: chrome plated mounting and adjusting your Pro Shop is a national Please ask. (Installation instructions are not included) [for steering judder and shimmy] as a handle axle rigid vehicle shake-specific, such as braking or steering of the road surface roughness (handle) is a general term for severe symptoms shaky on both sides. The same is slightly blurred steering shimmy at low speeds also given. Resolution of these methods work is required so make sure to check one by one to multiple factors, not only completely eliminate pre-load system is not the kingpin. Yukimasu cited the cause of the handle caused the shimmy from past practices in the pro shop Apio. In addition they may also have occurred in relation to each other, not because of their own.
Camels have nice toes
Vehicle: 07 vvt jimny
Post Posted: Tue Sep 13, 2011 6:49 am
lots of talk about this, and everyone I have seen with the 40mm OME kit needs to 2.5" - 3" castor correction bushes, they never had the problem them boom as soon and ome in they get the wobbles.
I would say spend your money on those before anything else. and invest in a steering damper if u dont have one already.
I have done the whole hub assembly upgrades and fixes and wheel alignment and still get them slightly, so its definalty the castor on mine now.
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Tue Sep 13, 2011 7:02 am
100% correct.
Was perfect before OME ...afterwards thought I'd die.
Caster correction and steering dampener and perfect again.
 Profile YIM
Post Posted: Tue Sep 13, 2011 7:20 am
Anyone good at searching????
Look for Mr Nutter's thread on " group action Jimny wobble"
There is stupid amount's of info in there.
P.S. it's the king pin adjustment, steering dampener will help to..
Post Posted: Tue Sep 13, 2011 7:46 am
nah, apparently i just tell people to search & not provide links. :lol:
Post Posted: Tue Sep 13, 2011 7:49 am
my shit wobbles & will suzuki help me thread can be found here http://auszookers.com/index.php?name=Fo ... mny+wobble
Users browsing this forum: No registered users and 66 guests
