http://auszookers.com/forum/
Transfer case mounts.
http://auszookers.com/forum/viewtopic.php?f=5&t=25216
Author:  strutts [ Sun Aug 28, 2011 10:59 am ]
Post subject:  Transfer case mounts.
Hey guys. I snapped one of my transfercase mounts. Not too sure if there standard mounts though. Can someone tell me what size are standard mine look about 50mm high.
Also my transfer wont stay in 4L which can be kinda dangerous going down hill lol. My front diff has been moved forward. Its like a 25mm spacer i think :/ could this be the reason why it keeps popping out?
Author:  shep [ Sun Aug 28, 2011 11:01 am ]
Post subject:  Re: Transfer case mounts.
has it got a body lift? if yes then the gear stick is hitting the floor.
Author:  strutts [ Sun Aug 28, 2011 11:09 am ]
Yeh its got a 50mm body lift. So thats why it pops out of 4L? Angle grinder will fix this? :D lol
Author:  nato78 [ Sun Aug 28, 2011 11:26 am ]
Just bash the hole in the transmission tunnel with a fucken big hammer until there's plenty of room around the stick
Author:  strutts [ Sun Aug 28, 2011 11:46 am ]
Hahaha sweet ill get onto it tmrw hopefully can get some mounts for my transfer aswell so the damn thing stops vibrating ><
Author:  lyallrichards [ Wed Aug 31, 2011 11:03 am ]
just bend the stick slightly, that way no chance of rust forming in the body
Author:  jdk81 [ Thu Nov 17, 2011 2:17 pm ]
Don't know if you have fixed it or not.
Have you chcked your transfer case brackets?
http://auszookers.com/index.php?name=Fo ... 526#496526
Mine did the same thing.
Rooted uni joints before I fixed it.
Author:  mrw82 [ Thu Nov 17, 2011 8:11 pm ]
check that the transfer mount arm isn't bent or twisted.
Author:  Teracis [ Thu Nov 17, 2011 8:23 pm ]
Instead of cutting or bashing, if you have a 50mm bodylift, put in a 50mm transfer lift.
More clearance, no bashing, transfer will work normally again!
