| g13a with 1.6 head timing belt installation. wont tighten http://auszookers.com/forum/viewtopic.php?f=5&t=25246 |
| Author: | CompTruck [ Mon Aug 29, 2011 8:11 am ] |
| Post subject: | g13a with 1.6 head timing belt installation. wont tighten |
hi again mates. im trying to put my timing belt on my motor. i bought the timing belt for the g13a motor. seems to be same length as the one that i pulled off it but havent counted the teeth. i try to put it on with the drive side tight but it either still skips a tooth or if i get it not to the other side of the belt with the tensioner doesnt tighten anyway. can someone tell me every step to do. i did it as per the manual as i understand it but maybe im wrong |
| Author: | CompTruck [ Mon Aug 29, 2011 2:34 pm ] |
| Post subject: | Re: g13a with 1.6 head timing belt installation. wont tighten |
come on guys. needa go up some hills soon |
| Author: | jimbo_jones [ Tue Aug 30, 2011 6:08 am ] |
I dont think they would use the same belt count the teeth |
| Author: | shep [ Tue Aug 30, 2011 6:14 am ] |
the timing pulleys have different shaped teeth as well. |
| Author: | CompTruck [ Tue Aug 30, 2011 7:19 am ] |
yep better count the teeth i rekn. does anyone know which one to use with g13a bottomend with 1.6 head? single cam. unsure exactly what head it is. definately has a different head to the 1.3. bigger valves |
| Author: | Jasen [ Tue Aug 30, 2011 8:21 am ] |
Use the cam pulley from ur old 1.3 head as that way the cam/crank tooth profiles will be the same. You'll then just need a timing belt for a g13a (make sure it's the square tooth profile most g13ba & g16a have round tooth profiles). If you're having trouble fitting the belt - take the adjuster bolt out of the tensioner plate so you can swing the tensioner way back out of the way when fitting the belt. Makes life a little easier I've found. You can also rotate the cam pully a tiny bit to get a bit of slack. As long as your timing marks line up once you've tightened the tensioner you'll be right. |
| Author: | CompTruck [ Tue Aug 30, 2011 9:05 am ] |
ok thanks. its already been run with this conversion so i believe i have the right belt being the g13a one. il have another go and count the teeth to confirm |
| Author: | CompTruck [ Tue Aug 30, 2011 1:26 pm ] |
found the problem. was trying to do it with the belt on the wrong side of the tensioner. blahahahaha will do it tomorrow |
| Author: | skyman [ Wed Aug 31, 2011 6:42 am ] |
That'll do it every time |
