| Help plz car running teribal http://auszookers.com/forum/viewtopic.php?f=5&t=25274 |
| Author: | Bennyzarb [ Tue Aug 30, 2011 7:56 am ] |
| Post subject: | Help plz car running teribal |
My 92 sierra is running bad ok when I take off fast in first she doesn't like it and the revs jump around and if I put my foot to the flood she will stall her self I have to take off very slow and when I get into second and put my fut down she only does it a little bit it jumps around 3 at 4 thousand revs in second but in any other gear she if fine and running great it seams like when I put lots of load on the engine she doesn't want to go Idl is fine you can rev it and it nothing happens it only does it when I take off Could you pls help me What do you think it could be? |
| Author: | nascpro44 [ Tue Aug 30, 2011 8:15 am ] |
| Post subject: | Re: Help plz car running teribal |
Could it be ur clutch sliping under load ? Not sure just throwin it outthere |
| Author: | reeceh [ Tue Aug 30, 2011 8:17 am ] |
I would say start with the basics mate, fuel filter, spark plugs/leads check them out to begin with. Give ya airfilter a blow out aswell. Best problem solving is done with the basics. Then when all is ok start to think about timing and the slightly more advanced stuff. |
| Author: | christover1 [ Tue Aug 30, 2011 8:17 am ] |
fuel bockage, or fuel pump dead, or both. And make sure tank breather is clear, ie run with petrol cap off to test if its the prob. |
| Author: | Bennyzarb [ Tue Aug 30, 2011 1:54 pm ] |
Ok thanks I will try those |
