It is currently Tue Oct 20, 2026 12:56 pm
Post Posted: Wed Aug 31, 2011 4:01 am
was looking at this as its 5 minutes from my place.
http://www.ebay.com.au/itm/ws/eBayISAPI ... TQ:AU:1123
is it worth the effort to fix or not??
Post Posted: Wed Aug 31, 2011 4:11 am
Yeah looks alright. Specially if you can pick it up for $2500 :)
Post Posted: Wed Aug 31, 2011 4:14 am
+1 :wink:
Post Posted: Wed Aug 31, 2011 4:34 am
how hard is it to change the seals if thats all it is? ive done some engine work on nissan engines but not these. what else would you change and check? rough outlay that might be expected?
cheers
Post Posted: Wed Aug 31, 2011 4:41 am
NFI on cost, but i'd go check it out before bidding, it could be a failed head gasket or something similar.
Post Posted: Wed Aug 31, 2011 4:51 am
yeah im probably going to look nxt day or so. wreckers near parafield have 2.5l recon engine for around 3K so might be better of doing that
Post Posted: Wed Aug 31, 2011 4:57 am
Yeah definetly check it out, he says in the questions that he has no idea on its history.
Post Posted: Wed Aug 31, 2011 8:52 am
I just had a quick look at the GV H25 manual and there's a lot of similarity with the J20 that I've just teared down. What's worth noting if like me you were use to working on other types of engines (holdens/fords/nissans/mitsu), getting the head off one of these engines is a complete PITA!
Looks like its the same setup to with the lifters, making it completely impossible to change the valve stem seals with the head on like you can do with most other engines I've worked on.
So even if it is just valve stem seals expect to be removing the engine, pulling timing cover, chains, sump, cams, heads, etc. Days of work.
Post Posted: Thu Sep 01, 2011 2:29 am
ahhh thanks for that
Post Posted: Thu Sep 01, 2011 4:21 am
SUZUKI VITARA ENGINE
Part Fits - 1995 - 1998 2.0 H20A V6 03/95-03/98
Ref No:1010-04
$1650.00
South Australia
that might be an option?? how much differant is the 2.5 in regards to wiring manifold and extra bolt on stuff??
Users browsing this forum: No registered users and 220 guests
