It is currently Tue Oct 20, 2026 12:56 pm
Post Posted: Wed Aug 31, 2011 5:23 am
hi guys im only new to zuks and haved searched but cant seam to find any info on how to move my front diff forward to run 33s.
its a 92 sierra with wt diffs . it has the calmini shackels reversal kit in it and calmini 2" lifted leaf springs.
any info on how to move my diff forward will be great
and sorry if this info is already on here but i did search
cheers guys
Post Posted: Wed Aug 31, 2011 5:25 am
with the shackle reversal on it, it will be extremely hard to move the front diff enough to clear 33s
Post Posted: Wed Aug 31, 2011 5:27 am
Just redrill the perches on the diff housing.
If you don't get stuck you aint tryin' hard enough
Post Posted: Wed Aug 31, 2011 6:01 am
hmm ok so the reverse shackels make it harder . damn
Post Posted: Wed Aug 31, 2011 6:05 am
yep its harder because they make the diff move toward the fire wall when the diff moves through its travel.
standard spring setup it moves away.
Post Posted: Wed Aug 31, 2011 6:09 am
so drill the pirch on the diff might be the way to go ?
or maybe i should spring it over and drop the lift thats in it
Post Posted: Wed Aug 31, 2011 6:10 am
i would
do a guard chop to fit the 33s
do a rear up front
piss off the shackle reversal.
Post Posted: Wed Aug 31, 2011 8:17 am
tanshi wrote:
i would
do a rear up front
X eleventy.
Vehicle: '94 suzuki maruti
Post Posted: Wed Aug 31, 2011 8:23 am
off topic, but what is the purpose of a shackle reversal?
Vehicle: SUZZI
like tanshi said rears up front and chop away like :crazy:
WELCOME onboard by the way mate :helloo:
lux diffs,twin locked,crawler gears,37s,etc
Post Posted: Wed Aug 31, 2011 8:31 am
No idea.... and I ran one :D
Actually, they theoretically improve ride because the axle path is more rearwards, so as the car hits a bump the axle moves up and back instead of trying to push forwards.
Steering improves because the drag link is on the same side of the axle as the fixed chassis mount so there's less shackle wobble as you steer, however, the downside is that as the car body rolls, the axle rolls against the steering instead of with it.
There's no good reason to run one.
Vehicle: SUZZI
Post Posted: Wed Aug 31, 2011 8:50 am
if your wanting to move your diff forward why dont you at the same time chuck a set of lux diffs under her and be done with it :D kill two birds with one stone. :)
Post Posted: Wed Aug 31, 2011 8:57 am
my front diff is about 6" forwards from stock.... i run 31's and had to add bumpstop spacing to stop the tyres hitting behind the headlights, even after a ton of metal was chopped out under there =P
Post Posted: Wed Aug 31, 2011 9:17 am
Because that would be pointless unless the OP wants to run over a 33" tyre, and there's no indication they want to do that.
Vehicle: SUZZI
Post Posted: Wed Aug 31, 2011 10:37 am
he will lol dexter?? you know you wanna :wink:
Tritain
Post Posted: Thu Sep 01, 2011 12:17 pm
Yeah Tritain you know as soon as I find a set of lux diffs with lockers I'll put them in and coil front and rear. It's just a money and time situation lol
Users browsing this forum: No registered users and 220 guests
