It is currently Mon Jun 22, 2026 6:25 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
Vehicle: 91 sierra swb nt
Post Posted: Wed Aug 31, 2011 9:02 am
I'm looking for suggestions for a carby for my 1.3, i've heard a carby off a 4k corolla will go on but want more info if anyone can help??
all constructive info is appreciated :D
Post Posted: Wed Aug 31, 2011 9:06 am
All the info you could ever want on the 4k carb conversion here. :wink:
http://auszookers.com/index.php?name=Fo ... 65&start=0
Vehicle: Ducati Monster
Post Posted: Wed Aug 31, 2011 9:57 am
weber 32/36 as long as you dont want a snorkel or on any real steep hills, i thought i read somewhere about a fix for this but i cant remember what it was, not super helpful but my 2 cents worth
Post Posted: Wed Aug 31, 2011 10:21 am
what happen's if u have a snorkel and a 32/36?
if u drive a loud toyota ute u drink rum
Post Posted: Wed Aug 31, 2011 10:22 am
Trawl outerlimits4x4 for jrzook and builtforthrashings mega weber thread in the samurai/Sierra bible. On my phone and cbf trying to link it.
You can have both...
Vehicle: 4wd
Post Posted: Wed Aug 31, 2011 10:25 am
I'd stick with the standard carby and get it overhauled if it's not running right.
Watch out or you'll get sued.
Post Posted: Wed Aug 31, 2011 10:31 am
X2 :wink:
Post Posted: Wed Aug 31, 2011 10:36 am
http://www.outerlimits4x4.com/viewtopic.php?t=28919 outers weber thread
if you fit a snorkel, make sure you don't live near a penguin colony as it's been proven that it causes them to start flying & that shit anit cool.
Post Posted: Wed Aug 31, 2011 11:00 am
k thanks
Post Posted: Wed Aug 31, 2011 11:35 am
wow, thanks guys, i wasnt gonna check for responses till tomorrow but happy i did :)
the standard carby i have now needs work, it idles really low on cold startup and seems to just be dumping fuel like its turning on a tap, i can smell it while im driving.
Post Posted: Wed Aug 31, 2011 12:15 pm
Try a new airfilter or giving your current one a really good clean (blow it out with an air compressor). :wink:
Post Posted: Wed Aug 31, 2011 11:19 pm
ill do that this afternoon, thanks for that idea.
does the 4k carby bolt strait on or do i need something else for it?
Vehicle: Coily.
Post Posted: Wed Aug 31, 2011 11:35 pm
Brother has just purchased a Coily and has similar problems,engine is running way too rich,terrible MPG & exaust pipe is covered in soot like a chimney.
Might try the Toyota carby before reco'ing the original.
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Thu Sep 01, 2011 1:47 am
Have you checked the choke?
Post Posted: Thu Sep 01, 2011 6:02 am
yeah, kinda, lol, i know the auto choke is stuffed, it idles warm at 1100rpm and has trouble starting when cold, also at the back of the carby there is a spring on a plastic thing that i think controls the auto choke and that thing is broken and the butterfly just sort of floats and does what it wants. this is one of the reasons i am thinking of changing the carby to something with a manual choke...
Post Posted: Thu Sep 01, 2011 9:16 am
vitara carb :wink:
Member of C.O.R 4x4
Post Posted: Thu Sep 01, 2011 9:13 pm
zooker wrote:
vitara carb :wink:
i've read that the vit carby isnt that good ??
Post Posted: Fri Sep 02, 2011 12:23 am
How bout you start by holding the choke flap open so it 'doesn't do want it wants' lol lol LOL............
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Sep 07, 2011 8:10 am
Try a new airfilter or giving your current one a really good clean (blow it out with an air compressor). :wink:[/quote]
so i put a new air filter in, since it was only 16 bucks, it seems to start better but the smell is still there, kinda out of ideas now, other than getting another one and overhauling it that way i dont have to bee off the road..
Post Posted: Wed Sep 07, 2011 8:23 am
so i put a new air filter in, since it was only 16 bucks, it seems to start better but the smell is still there, kinda out of ideas now, other than getting another one and overhauling it that way i dont have to bee off the road..[/quote]
Lil Foot!
Post Posted: Wed Sep 07, 2011 9:21 am
Oh my, we could be here a while...
Zip tie, remove or repair the choke butterfly for starters.
Post Posted: Wed Sep 07, 2011 9:24 am
It is more than probable that the choke butterfly is closed even when up to operating temp and driving. This will pull shitloads of fuel through the primary jet making it run like shit and stink like shit.
Now go sort that shit!
Post Posted: Wed Sep 07, 2011 9:54 am
These guys are on the money mate. I just cable-tied the flap open as my little spring had lost all tension and the choke could flap about whenever it wanted. Had exact same symptoms as you. My plan was to rebuild the carb, however since I tied the choke open my car uses less fuel, idles much nicer and funnily enough revs more freely under load and feels like it's got more torque all round. When working correctly the choke only affects your car until warm. If you've still got problems (when the car is warm) after you tie it open then at least you can rule out the choke flap causing those problems. Who knows u could be lucky like me and find out ur carb aint too bad after all - it was just the choke doin it's own thing lol.
Post Posted: Thu Sep 08, 2011 1:57 am
i ran a 32 36 it went well but drank the juice plus some angles it didnt like
Post Posted: Thu Sep 08, 2011 6:40 am
ok, i cable tied the choke and that seems to have worked quite well, still a smell but no where near as much as there was before :) thanks guys :) assuming i get better fuel consumption im gonna leave it the way it is till i have money for an engine transplant :)
Post Posted: Thu Sep 08, 2011 12:40 pm
Cool. If you get real excited you can remove the butterfly flap via the two phillips head screws.
How's it go on the highway? Sit on 100kmh no prob? 110kmh?
Vehicle: 92 Suzuki Sierra
Post Posted: Thu Sep 08, 2011 12:47 pm
x2
also check you float level (and if its all there... i've had two snapped floats in 7 years) It may be spitting out bits of fuel. (if its downright dumping it your car we flood and run really rough if at all)
-Santos
Post Posted: Thu Sep 08, 2011 12:53 pm
i removed the shaft as well :wink:
Post Posted: Thu Sep 08, 2011 12:58 pm
some old vacuum tubing and a m4 screw block it off real nice
-Santos
Users browsing this forum: Google [Bot] and 86 guests
