It is currently Tue Oct 27, 2026 12:38 am
Post Posted: Thu Sep 01, 2011 10:44 pm
I've brought home a new zook with a heap of surface rust. No rust holes where's rusted threw which is why I brought it. However I have NFI about the procedure on rust repairing surface. I've wire wheeled it down so the rust is like that pock marked stuff like so:
Now do I keep taking it back to bare or should I get rust converter and convert, then bring it back again? Is that how it works?
Post Posted: Thu Sep 01, 2011 10:59 pm
I personally would take it back to bare metal to try as best as possible to stop it from spreading..
swb sierra, bundera diffs, spoa on yj leaves, 35's
Post Posted: Thu Sep 01, 2011 11:01 pm
Isn't that what rust converter does? Change it back to something work able to be cleaned up and painted?
Vehicle: 75 Cruiser
Post Posted: Thu Sep 01, 2011 11:06 pm
If you want to keep the car for a long long time maybe put a fair bit of time in?
I'd just use rust converter then spray tar on it, go 4wding, keep it for two years then it'll be wrecked by then and buy another one.
Post Posted: Thu Sep 01, 2011 11:07 pm
So bring it all the way back? Thanks Steve.
Post Posted: Thu Sep 01, 2011 11:25 pm
checked the other side of the panel to make sure it didnt start there?
get rid of as much rust as you can and then rust convert it.
Post Posted: Fri Sep 02, 2011 12:14 am
It's on the bonnet and the tops clear. I brought it back so it was pock marked but no rust in the pock marks.
Post Posted: Fri Sep 02, 2011 12:27 am
Vehicle: On the lookout
Post Posted: Fri Sep 02, 2011 12:56 am
x2. there's a brandname 'KRUST' that stuff is good. Turns really deep flakey rust into a hard surface and you just paint over it for a rough and ready finish to keep you going for a couple of years. Tar over any rust under the car so that the Pink slip man can't see it.
You can also buy 'ammorite' paint that has rust treatment included. Comes in standard colours, white, black. It ain't pretty but it's hard and it stops the rust from spreading.
Post Posted: Fri Sep 02, 2011 1:10 am
Yeah thats good. Just do as Steve said. Rust convert, then paint. Be carefull using a grinder to clean up rust on panels, as the heat generated can a) Warp the panel, or b) blister the paint on the other side.
Post Posted: Fri Sep 02, 2011 1:13 am
Using one of them blue wire wheel drill attachments thing from bunnings. No grinders yet :D It's like in between a flapper disc and a wire wheel? That has blue cement stuff on it? Like a kitchen scourer.
Post Posted: Fri Sep 02, 2011 1:15 am
Its still an abrasive. Just take it slowly. :wink:
Post Posted: Fri Sep 02, 2011 2:13 am
Ok. Thanks for the advice. Almost done the drivers side sill. Bit more rust there. But only 2 the size of half a 5 cent piece? Where the tac welds were.
Post Posted: Fri Sep 02, 2011 3:22 am
That and I found out the hard way how goddamn thin Sierra panels are, you might be taking paint off.... But you be taking away precious metals too :(
Sand, rust convert. If you have the patience/skill weld in replacement sections.
Check out a product called POR15 to seal it up with afterwards.
Post Posted: Fri Sep 02, 2011 5:45 am
Definitely go with POR 15 used it many times, its the ducks nuts you dont even need to rust convert it just paint it on
Post Posted: Fri Sep 02, 2011 6:32 am
It's all pretty awesome under the sil. Just those little holes I mentioned. Brought it back as far as I could. Just smashed it with rust convert. Where is POR15 available from? I was gonna use rust kill heavy duty primer after I'd converted it. Then bog to smooth it out, sand back and primer all over then paint. Sound about right?
Post Posted: Fri Sep 02, 2011 9:26 am
Where'd all my rust experts bloody go.
Vehicle: 2018 DMAX
Post Posted: Fri Sep 02, 2011 9:35 am
Those blue discs bunnings sell are the shit for removing rust and paint of flat stuff, but will heat up your panel up quickly..
As for Rust Kill heavy duty primer, make sure the surface is very clean and you allow 12hours between coats... For some reason that particular primer is very sensitive and fucks up easy... Maybe try a different primer...
I use Rainex rust converter, clean the area very well then prime and paint. The kill rust white top coat is the same colour as a stock white sierra.
Post Posted: Fri Sep 02, 2011 9:38 am
I used rainex as well. The places will be thoroughly cleaned with turps and wax n grease remover. Then a coat of the heavy primer. Up here in the sun it'd probably only need a few hours. Not humid at all yet. Give it another good clean and another coat. Then filler to fill the pocks. Sand and clean. Primer. Then paint. Yes?
Vehicle: 2018 DMAX
Post Posted: Fri Sep 02, 2011 9:45 am
Filler should really go onto metal not paint. Depending on how deep the marks are you could use some spray putty, which is really just a thick primer anyway. Or just fill over the primer, and probably not have an issue for quite a few years anyway.
Post Posted: Fri Sep 02, 2011 9:48 am
Spray putty. I shall use this. It's my first paint job :D.
Users browsing this forum: No registered users and 284 guests
