It is currently Wed Nov 04, 2026 11:05 am
Post Posted: Sat Sep 03, 2011 6:58 am
After a jolly old bash on the beach the other day, stopped the vit to get out and have a chat, then went back in and all of a sudden the gear stick went completley sloppy, still selects gears fine and all.
After a bit of searching on here i pulled it apart and found the boot had cracked and let in a head of sand and water. The spring, bolts and ball seemed in good condition, so i cleaned them up and put it all back together, after draining the water and adding grease.
Trouble is, its still exactly the same.
Everything in that picture was there and cleaned and greased.
Dad put it down to a worn ball on it, but it seems odd that that would give up all of a sudden?
Help would be appreciated greatly!
Post Posted: Sat Sep 03, 2011 7:36 am
you haven't just got it in neutral ;)
Stocker
Vehicle: Nissan
Post Posted: Sat Sep 03, 2011 7:41 am
there is a bush that sit on the ball when its in the box this is most likely your problem
http://www.suzistore.com.au/shopexd.asp?id=618
Pearce-toff Racing
Post Posted: Sat Sep 03, 2011 7:48 am
Does this rubber go in the box or the end of the gear stick.
Mines very sloppy also. I figured it was normal
Vehicle: Nissan
Post Posted: Sat Sep 03, 2011 8:02 am
there is a pic oin here that shows you how it sits in
http://www.suzuki-forums.com/suzuki-sid ... -pics.html
Pearce-toff Racing
Post Posted: Sat Sep 03, 2011 8:32 am
Cheers for the replies guys.
Does the smaller bush go over the end ball, because that would explain things.
The thing had sand in it cause of the cracked boot so that may had done it.
Vehicle: 02 GV
Post Posted: Sun Sep 04, 2011 6:03 am
that plastic bush is called a sheet and can be bought from suzuki for about $12 from memory.
Post Posted: Sun Sep 04, 2011 9:03 am
I rang the turds and they said the gearstick is sold as one whole piece. Woudlnt you have to cut it to replace the bushes but?
Post Posted: Sun Sep 04, 2011 9:11 am
Yep and I make and sell them for $5.00 + postage :wink:
Post Posted: Sun Sep 04, 2011 9:35 am
Bruce/bailey is that the bush that usually fails making them sloppy? if so i wanna buy one.
Post Posted: Sun Sep 04, 2011 9:40 am
Or it could be the Special bolt. 99% of the time on a Sierra it's the bush.
Vehicle: Nissan
Post Posted: Sun Sep 04, 2011 9:41 am
sorry Bruce i forgot you make them :oops:
Pearce-toff Racing
Post Posted: Sun Sep 04, 2011 9:44 am
No worries mate. It's not the $5 I need but happy to help AZ guys out if I can save them some coin :wink:
Users browsing this forum: No registered users and 103 guests
